[Geoserver-users] Java questions
Our server is 64-bit Ubuntu 12.04 server (Intel).
What is the recommended version of Java? Now it is 1.7 64-bit.
If the recommended version is 32-bit on a 64-bit system, what versions of native JAI and IMAGEIO should I use?
I have a all-32-bit configuration on test computer (Intel Xeon) and no problems with it. The 64-bit production server needs to be booted now and then. It works ok when reading the data, but if I try to add data or change something, I get the “Sorry, timed out” or something like that errors.
Oiva
Agrifood Research Finland
On Wed, Aug 14, 2013 at 10:05 AM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com>wrote:
That should work, but java 6 64 bits is better tested
The 64 bits version
something, I get the "Sorry, timed out" or something like that errors.
That error message sometimes hide the real issue, which might be something
else, maybe a write permission issue.
Can you check the logs? (and make sure the folders holding the data dir are
writable for the user running GeoServer,
otherwise not even the logs will work)
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
OK, thanks Andrea.
I must look at the Geoserver log and try to find a reason for the problem. I think it is not file system problem, because after a Geoserver reboot everything (adding data etc.) works fine. Our system admin set up Geoserver to work under Jetty and that is among the first things to change. I already know how to set up Tomcat, Geoserver, native JAI and IMAGEIO.
Oiva
That error message sometimes hide the real issue, which might be something else, maybe a write permission issue.
Can you check the logs? (and make sure the folders holding the data dir are writable for the user running GeoServer,
Ing. Andrea Aime
@geowolf
Technical Lead
