[Geoserver-users] Java upload error on GeoNode travis-CI server
Hello list,
I’m writing you on behalf of the GeoNode developer community, we are recently experiencing a Geoserver error on the CI server, just there, we can’t reproduce it in local machines, vagrant test environments etc. The error appeared at some point after a commit that is totally unrelated with that (a small javascript fix) and never went away.
The integration tests load some layers that we use for GeoNode internals, it happens that sometimes one layer doesn’t load, note that is not the same layer.
The final error is a java.lang.NullPointerException
The full travis trace can be found here https://travis-ci.org/GeoNode/geonode
We also created a “verbose” pull request in order to get more information and are listed in the relative ticket here https://github.com/GeoNode/geonode/issues/1288.
We appreciate a lot any help or advice you could give us.
Thanks in advance
The GeoNode devs.
Simone
