Hi all (and sorry for posting twice, something went wrong with my list subscription),
I'm trying to get geoserver working for me, but am not very successful at that till now...
I would like to build the latest&greatest wcs branch, so I got the source from svn (I used 'svn checkout svn://svn.codehaus.org/geoserver/scm/branches/
trunk/geoserver', is that correct?).
Then I run 'ant test' in the geotools directory to build the jar en start the jetty server. Till this point everything works, though there are some
warnings. But when I try to access http://localhost:8080/geotools, I get lots of errors like the following (which is the last one, but every .do file
generates such an error):
[java] ERROR compiling http://localhost:8080/geoserver/config/validation/test.do
[java] 17:16:56.949 WARN!! Exception for /geoserver/welcome.do
[java] javax.servlet.UnavailableException: Could not instantiate class org.apache.struts.action.ActionServlet
[java] at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:335)
[java] at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:342)
[java] at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
[java] at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:334)
[java] at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:286)
[java] at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
[java] at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
[java] at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)
[java] at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
[java] at org.mortbay.http.HttpServer.service(HttpServer.java:879)
[java] at org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
[java] at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
[java] at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
[java] at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
[java] at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
[java] at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
So something seems to be wrong with struts?
I tried with java 1.5 (my default) as well as java 1.4, but that made no difference.
Anybody any ideas?
Vincent Schut.
