[Geoserver-users] jdbcconfig module
Hello List,
I tried to configure jdbcconfig extension for GeoServer. It works good – saves settings to PosgreSQL and all 3 clusters can successfully Access it.
But I notice one thing – jdbcconfig has no impact for TileCaching ( Tile Layers) – changes on master GeoServer instance for Tile Layers were not sinchronized between instances.
Does jdbcconfig module supports GeoWebCache settings? Or maybe it is just for GeoServer settings?
I am using geoserver 2.4.war on Windows Server 2008R2 X64 on Tomcat6 + jdk1.6 x64.
Sincerely,
Paul
Hi Paulius,
I’m not sure to understand exactly what do you mean with impact on TileCaching, what exactly you want to do?
GeoWebCache saves the tiles on the mass storage, if you change the layer you have to invalidate the cache in order to regenerate the new tiles. The jdbcconfig module has no effect on this behavior.
-A.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Mon, Sep 30, 2013 at 9:36 AM, Paulius Litvinas <paulius@anonymised.com> wrote:
Hello List,
Sincerely,
Paul
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Alessio,
I have 3 GeoServer clustered instances with load balancing.
After I installed jdbcconfig module I added new layer on one GeoServer instance. I understand that with jdbcconfig module settings are stored on PostgreSQL and sinchronized between other instances (using same data dir). The same new layer appeared automaticaly on other GeoServer instances without restarting (reload config).
Also on one GeoServer instance I created tile cache for this layer, but unfortunately this tile cache did not appeared on other GeoServer instances. I had to reload config, so I gues settings for GeoWebCache is stored in files.
I expected that GeoWebCache settings also are stored in same database using jdbcconfig module and they will be sinchonized automaticaly on all GeoServer instances.
Paul
From: alessio.fabiani@anonymised.com [mailto:alessio.fabiani@anonymised.com] On Behalf Of Alessio Fabiani
Sent: Monday, September 30, 2013 10:44 AM
To: Paulius Litvinas
Cc: geoserver-users
Subject: Re: [Geoserver-users] jdbcconfig module
Hi Paulius,
-A.
more information.
@alfa7691
Hello List,
Sincerely,
Paul
On Mon, Sep 30, 2013 at 10:01 AM, Paulius Litvinas <paulius@anonymised.com>wrote:
Hi Alessio,****
I have 3 GeoServer clustered instances with load balancing.****
without restarting (reload config).****
stored in files.****
Nope, you're right, GeoWebCache uses a separate set of xml files to store
its configuration, which makes it
unreachable for the jdbcconfig module.
This is true for a number of other extensions and subsystem, there was a
question about which config elements
are actually stored in the db, and which not, some time ago on this list,
have a look in the archives, I've tried
to list things that cannot be stored in the dbms without also changing the
way those GeoServer modules work
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Ok. I got it. Thanks for the help
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Monday, September 30, 2013 11:10 AM
Cc: Alessio Fabiani; geoserver-users
On Mon, Sep 30, 2013 at 10:01 AM, Paulius Litvinas <paulius@anonymised.com> wrote:
Hi Alessio,
Nope, you’re right, GeoWebCache uses a separate set of xml files to store its configuration, which makes it
This is true for a number of other extensions and subsystem, there was a question about which config elements
are actually stored in the db, and which not, some time ago on this list, have a look in the archives, I’ve tried
to list things that cannot be stored in the dbms without also changing the way those GeoServer modules work
Ing. Andrea Aime
@geowolf
Technical Lead
Chiming in late on this one.
When it comes to cluster synchronization the jdbconfig module only solves part of the problem, and the synchronization problem pops up elsewhere, most notably in the ResourcePool. It is not a problem for adding new configuration objects but is a problem for updating existing ones.
For instance consider changing the configuration of an existing data store. Even though every node in the cluster will see the changed configuration the next time they access that store they won’t know it changed so won’t know to expire the cached resource for it.
The only way I have seen this effectively solved is with the addition of a messaging/synchronization component that nodes in the cluster use to broadcast change events to the rest of the cluster.
On Mon, Sep 30, 2013 at 2:12 AM, Paulius Litvinas <paulius@anonymised.com> wrote:
Hi Alessio,
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
