[Geoserver-users] jdbcconfig - performance issue with 11K layers
I’ve been trying out the jdbcconfig module with a data catalog of about 11,500 layers (~1000 geotiffs, a few hundred shapefiles, and the rest in a PostGIS datastore). Immediately after the initial import of the data catalog, the responsiveness of Geoserver seems fine, for instance when accessing the list of layers from the administration interface and paging through results. However, after Geoserver is restarted, or if the configuration/catalog is reloaded from the admin interface, then it becomes far slower - taking over 2 minutes to display each page of layers from the admin interface.
I connected to the code running in my Tomcat instance remotely via Eclipse and it seems that this line in the ConfigDatabase class is where it takes so long to process:
https://github.com/geoserver/geoserver/blob/master/src/community/jdbcconfig/src/main/java/org/geoserver/jdbcconfig/internal/ConfigDatabase.java#232
The same line returns quickly immediately after the initial catalog import. But I haven’t yet been able to figure out why. Could it be that I simply have some setting misconfigured, or that there’s something wrong with my data catalog?
-Matt
Looks more like a limitation of the implementation, just before the line you mention the code has:
LOGGER.fine(“Filter is not fully supported, doing scan of supported part to return the number of matches”);
So I expect work is required to ensure that database can handle the query. Are you using the default H2 database or PostgreSQL?
You can see where a similar issue has been previously fixed on GEOS-5968.
Jody Garnett
On Wed, Mar 12, 2014 at 4:09 AM, Matt Bertrand <mbertrand@anonymised.com> wrote:
-Matt
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/13534_NeoTech
Geoserver-users mailing list
Thanks Jody,
I have tried using both the PostgreSQL and H2 database, with the same result. And what's odd is that the same line of code is executed when Geoserver initially responds quickly as when it later responds slowly. Maybe it's a caching issue?
-Matt
   LOGGER.fine("Filter is not fully supported, doing scan of supported part to return the number of matches");
You can see where a similar issue has been previously fixed on GEOS-5968 <https://urldefense.proofpoint.com/v1/url?u=http://jira.codehaus.org/browse/GEOS-5968&k=AjZjj3dyY74kKL92lieHqQ%3D%3D &r=E51gnZ%2BcyXbMGQZxn%2FD1gw7E4%2FG%2Bn9A8lGzpPjSUKD4%3D &m=QuiunhjzwhnjewJu0voBPL5xU9BTeRCly%2FT0GlLQuMU%3D &s=400dfc1485c4e3d5c7a32c02aefc08aff7221b25096fa8dda0ddbf0683eab7b1&gt;\.
Jody Garnett
On Wed, Mar 12, 2014 at 4:09 AM, Matt Bertrand <mbertrand@anonymised.com <mailto:mbertrand@anonymised.com>> wrote:
    I've been trying out the jdbcconfig module with a data catalog of
    admin interface.
    <https://urldefense.proofpoint.com/v1/url?u=https://github.com/geoserver/geoserver/blob/master/src/community/jdbcconfig/src/main/java/org/geoserver/jdbcconfig/internal/ConfigDatabase.java%23232&k=AjZjj3dyY74kKL92lieHqQ%3D%3D &r=E51gnZ%2BcyXbMGQZxn%2FD1gw7E4%2FG%2Bn9A8lGzpPjSUKD4%3D &m=QuiunhjzwhnjewJu0voBPL5xU9BTeRCly%2FT0GlLQuMU%3D &s=e14c7842550b0d024558f47f1595a50fe162c1ab34f1a03feb72249a8ba1c2a6&gt;
    catalog import. But I haven't yet been able to figure out why. Could it be that I simply have some setting misconfigured, or that
    there's something wrong with my data catalog?
    -Matt
    Learn Graph Databases - Download FREE O'Reilly Book
    "Graph Databases" is the definitive new guide to graph databases
    and their
    <https://urldefense.proofpoint.com/v1/url?u=http://p.sf.net/sfu/13534_NeoTech&k=AjZjj3dyY74kKL92lieHqQ%3D%3D &r=E51gnZ%2BcyXbMGQZxn%2FD1gw7E4%2FG%2Bn9A8lGzpPjSUKD4%3D &m=QuiunhjzwhnjewJu0voBPL5xU9BTeRCly%2FT0GlLQuMU%3D &s=c43f27d2e71609b9136c7f688669205c45674deb105b9cd86af257d51c971fac&gt;
    <mailto:Geoserver-users@lists.sourceforge.net>
    <https://urldefense.proofpoint.com/v1/url?u=https://lists.sourceforge.net/lists/listinfo/geoserver-users&k=AjZjj3dyY74kKL92lieHqQ%3D%3D &r=E51gnZ%2BcyXbMGQZxn%2FD1gw7E4%2FG%2Bn9A8lGzpPjSUKD4%3D &m=QuiunhjzwhnjewJu0voBPL5xU9BTeRCly%2FT0GlLQuMU%3D &s=bc1ad5fdfeaa1f69a89321831ced0de3ef86a20b51c1a4afe9d4fc387b8b30d6&gt;
Well if you are into looking at code - perhaps stop it in a debugger and see what filter it is having trouble optimising?
At the very least we can use that information to report a new JIRA issue.
Jody Garnett
On Thu, Mar 13, 2014 at 7:00 AM, Matt Bertrand <mbertrand@anonymised.com> wrote:
Thanks Jody,
I have tried using both the PostgreSQL and H2 database, with the same result. And what’s odd is that the same line of code is executed when Geoserver initially responds quickly as when it later responds slowly. Maybe it’s a caching issue?
-Matt
Jody Garnett
-Matt
It's an "IsEqualsToImpl" filter - same type of filter before and after the slowdown. I created a new JIRA issue for this - https://jira.codehaus.org/browse/GEOS-6398, just wanted to run the problem by this list first though to see if it might be a known issue caused by a misconfigured setting somewhere.
-Matt
Jody Garnett
On Thu, Mar 13, 2014 at 7:00 AM, Matt Bertrand <mbertrand@anonymised.com <mailto:mbertrand@anonymised.com>> wrote:
    Thanks Jody,
    -Matt
    GEOS-5968
    Jody Garnett
        misconfigured, or that there's something wrong with my data
        catalog?
        -Matt
        databases and their
        today!
On Thu, Mar 13, 2014 at 4:56 PM, Matt Bertrand <mbertrand@anonymised.com>wrote:
It's an equals, but inside it's using a custom function, not surprised it
cannot be optimized, that function needs to
the transformed into some SQL (which I believe might be doable, the
function internally is just checking
if the layer is in a certain workspace, or not?)
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The function is checking if the the Advertised and Enabled flags are set on the layer, or its resource, or for layer groups it’s either always returning true or checking each sublayer depending on the specified visibility policy. It also checks if the request is a GetCapabilities request and only does something what it is a GetCap. I’ve posted in the dev list about the details. The particular page at issue here is an easy fix, but some other pages are much more complicated.
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
On Thu, Mar 13, 2014 at 4:56 PM, Matt Bertrand <mbertrand@anonymised.com> wrote:
It’s an “IsEqualsToImpl” filter - same type of filter before and after the slowdown. I created a new JIRA issue for this - https://jira.codehaus.org/browse/GEOS-6398, just wanted to run the problem by this list first though to see if it might be a known issue caused by a misconfigured setting somewhere.
It’s an equals, but inside it’s using a custom function, not surprised it cannot be optimized, that function needs to
the transformed into some SQL (which I believe might be doable, the function internally is just checking
Ing. Andrea Aime
@geowolf
Technical Lead
