after some time working on our new jira tracker I noticed that I kept on considering the old migrated
ticket troublesome and “to stay away from”, mostly because they are still lacking a number
of information in them.
So this week I decided to move from complaint to action and wrote myself a set of
small throwaway utilities to migrate some other bits from the xml dumps we have handy
For those interested, the dumps are avaiable at http://webextra.osgeo.osuosl.org/codehaus/
and the utils I’m using (pretty ugly code, you’re warned) are available
at https://github.com/aaime/jira-migration
For the moment I’ve migrated all “affect version”, “fix for version”, and issue type
from those files back in Jira, for GeoTools and GeoServer.
The process is pretty long, as the hosting tries to actively fight off mass changes and
logs me out, makes requests fail and so on (so I built a retry mechanism that stubbornly
retries the migration of a given issue if it fails).
Sometimes the migration has to be re-run 2-3 times regardless, and each run can take 2-3 hours,
but oh well, in the end the tickets get updated.
I’ve looked into removing the HTML tags, but that’s quite a bit of work that I’m not really prepared
to take on.
I’ve also tried to re-establish the relations between tasks and sub-tasks, in this case it’s the
little jira-client library I’m using that’s not playing ball, not sure if anything wants to take time to fix it,
right not I’m leaning towards migrating sub-tasks to tasks (sub-task cannot be assigned without
a parent, the parent is apparently not editable though with the library), and then link them back
to their parent as a “blocks” link.
Anyways, next on my plate is to try to reattach components, if at all possible, see if I can
relink issues, and again if it does not take too much time, try to re-attach authors now
that we have some user base logged into Jira. No promises, depending on how hard
and how inspired I am, I might do all or none of them (or something else entirely!)
The tools are generic, so they could be used to perform the same migrations for UDIG
and GeoApi, if anyone is interested, just run the MigrateApp and answer the questions
(warning, when it asks for the Jira password, it will show up in cleartext, so make sure you’re
alone when you run them… I’ve tried using the Console class, but it does not work
with the Eclipse console view, and I did not want to waste time setting up a maven
launcher…). Oh well, if you find it useful fork it, improve it, and if you feel like, send over pull requests.
PS: I wanted to re-release all the released versions in Jira (which are now un-released)
but the dumps do not contain any info about the release dates… so we’re out of luck date wise,
but the release notes seem to be working fine, e.g…:
https://osgeo-org.atlassian.net/jira/secure/ReleaseNote.jspa?projectId=10000&version=10139
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
