What do you think? Make a test plan and run. Attached is a simple one for WMS. Load it into Jmeter, create a “bbox.txt” file with bboxes that suit your data. One BBOX per line, comma separated.
To improve the test you have to learn how WMS/WFS/WCS requests are constructed and how to feed changing parameters into base requests. The bbox example helps with that and Jmeter documentation helps in understanding listeners etc.
-Jukka Rahkonen-
gs.jmx (11 KB)
Anas A wrote:
How to view the geoserver performance in jmeter ?
Regards
Anas A
+917736368236
