Ciao Simone,
Sorry for being slow to response. We implemented a work around where by we stopped using layer groups and instead just listed the layers in the LAYERS argument of our WMS request, but then realized that we can’t us GeoWebCache when doing that.
I’ve come back and tried to isolate this bug and find some repeatable steps. Here they are:
Sorry for the delay with coming back on this. I’ve managed to isolate this bug and make it easily repeatable with a standard setup.
Here’s the setup:
GeoServer 1: Clean install running 2.8, in it’s own Tomcat container, running JMS-Cluster with default settings.
GeoServer 2: Clean install running 2.8, in it’s own Tomcat container, running JMS-Cluster with default settings.
Both GeoServer’s are sharing the same data directory.
Steps to repeat:
- GeoServer 1, create new layer group. Use the “sf” workspace and the “streams” layer
- On GeoServer 1 go to layer preview and open the group layer in OpenLayers, it displays as expected
- Refresh GeoServer 2, we can now see the new layer group as expected
- On GeoServer 2 go to the layer preview and open the new group layer in OpenLayers
- We are returned a NullPointerException as an XML response. The same error is show in the GeoServer2 logs.
Attempts to resolve:
- Tried using 2.7
- Tried using external ActiveMQ Broker
- Tried using Master / Slave setup.
- Tried using individual data directories for each GeoServer instead of shared.
None of the above worked. I’ve also posted this information to the bug report. So it seems layer groups don’t work when using JMS Clustering in versions 2.7 or 2.8 (haven’t tried others).
When you have time, could you please check if you see the same thing when repeating the same steps as me?
Chris
On 22 October 2015 at 23:36, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Chris,
see my message on the JIRA report.
I have tested on master and it worked for me. We might need more info.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Oct 22, 2015 at 10:25 AM, Chris Brown <chris@anonymised.com> wrote:
Thanks Andrea, I’ve added a new bug report here - https://osgeo-org.atlassian.net/browse/GEOS-7263.
Chris
Geoserver-users mailing list
On 22 October 2015 at 15:03, Andrea Aime <andrea.aime@anonymised.com> wrote:
Chris Brown
MangoMap
On Thu, Oct 22, 2015 at 10:01 AM, Chris Brown <chris@anonymised.com> wrote:
Hi Andrea,
Thanks Andrea. That’s definitely not the case this time, we’re using a UUID for both the layer and group name. We’re using GeoServer 2.7.2.
In that case the issue is unknown, can you report it with a step by step way to reproduce it (best if against the default data dir)?
https://osgeo-org.atlassian.net/projects/GEOS/issues
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Chris Brown
MangoMap
