Hello Daniele,
That is interesting. I did not find either message in my log. So does that mean I don’t have the GDAL extensions enabled? How do I change that?
Bob
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Thursday, January 15, 2015 7:02 AM
To: Bistrais, Bob
Subject: Re: [Geoserver-users] jp2 images will not load
Hi again Bob,
if you have the GDAL extension on your GeoServer webapps your log should contain either:
… it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
INFO: GDAL Native Library loaded (version: 1.9.2)
OR
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.
Could you please check that?
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Wed, Jan 14, 2015 at 6:18 PM, Bistrais, Bob <Bob.Bistrais@anonymised.com.6406…> wrote:
Hi Daniele,
I looked in the log file, I did not find either of those entries. I searched using two different text editors.
Bob
From: dany.geotools@anonymised.com…84… [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Wednesday, January 14, 2015 11:56 AM
To: Bistrais, Bob
Hi again Bob,
could you check on your debug log if you find any entry like these?
org.geotools.gce.imagemosaic.ImageMosaicFormatFactory.hasJP2GDALMRSID
or
DEBUG [gce.imagemosaic] - Unable to load GDAL JP2 MrSID Reader SPI
And check what messages are around this line? (We are looking for some messages reporting that the GDAL JP2 MrSID driver has been properly loaded or not)
I also think that if you have configured your dataset without GDAL drivers being properly configured, you have to reconfigure it after the drivers have been properly set.
Please, let us know.
Daniele
On Wed, Jan 14, 2015 at 5:42 PM, Bistrais, Bob <Bob.Bistrais@anonymised.com.6406…> wrote:
Hi Daniele,
The GDAL_DRIVER_PATH was not configured. But I configured it, then rebooted the machine. I am still getting errors. I will paste it here, in case it is a different error than before, but it looks the same to me…
2015-01-14 11:38:02,676 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2015-01-14 11:38:02,677 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2015-01-14 11:38:02,678 DEBUG [org.geoserver] - Thread 14 locking in mode WRITE
2015-01-14 11:38:02,678 DEBUG [org.geoserver] - Thread 14 got the lock in mode WRITE
2015-01-14 11:38:02,717 DEBUG [org.geoserver.config] - Persisting coverage store jptest
2015-01-14 11:38:02,735 DEBUG [org.geoserver.config] - Persisted com.sun.proxy.$Proxy20 to workspaces/opengeo/jptest/coveragestore.xml
2015-01-14 11:38:02,747 DEBUG [org.geoserver.config] - Persisted com.sun.proxy.$Proxy35 to global.xml
2015-01-14 11:38:03,086 WARN [org.geotools.coverageio.jp2k] - Unavailable envelope for this coverage
org.geotools.data.DataSourceException: Unavailable envelope for this coverage
at org.geotools.coverageio.jp2k.JP2KReader.setCoverageProperties(JP2KReader.java:161)
at org.geotools.coverageio.jp2k.JP2KReader.(JP2KReader.java:504)
at org.geotools.coverageio.jp2k.JP2KFormat.getReader(JP2KFormat.java:123)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1418)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1346)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:59)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at com.sun.proxy.$Proxy20.getGridCoverageReader(Unknown Source)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:90)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:59)
at org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:237)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:566)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.(GeoServerTablePanel.java:559)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:171)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:96)
at org.geoserver.web.data.layer.NewLayerPage$1.(NewLayerPage.java:103)
at org.geoserver.web.data.layer.NewLayerPage.(NewLayerPage.java:103)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSuccessfulSave(CoverageStoreNewPage.java:79)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:70)
at org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:116)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:156)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919)
at com.boundlessgeo.geoserver.AppDispatcher.doDispatch(AppDispatcher.java:67)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:953)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:855)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:829)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:654)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1320)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1291)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at com.boundlessgeo.geoserver.AppAuthFilter.doFilter(AppAuthFilter.java:111)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:199)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:443)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:532)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:227)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1044)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:372)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:189)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:978)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:255)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:154)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:369)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:486)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:944)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:1005)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:865)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:668)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Unknown Source)
2015-01-14 11:38:03,087 INFO [org.geoserver.web] - Getting list of coverages for saved store file:C:\mapserver_data\wms_raster_data\augusta_man_08\tiles\19TDJ290855.jp2
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:C:\mapserver_data\wms_raster_data\augusta_man_08\tiles\19TDJ290855.jp2 and hints null
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:151)
Caused by: java.io.IOException: Failed to create reader from file:C:\mapserver_data\wms_raster_data\augusta_man_08\tiles\19TDJ290855.jp2 and hints null
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1420)
… 120 more
2015-01-14 11:38:03,088 DEBUG [org.geoserver.config] - Removing coverage store jptest
2015-01-14 11:38:03,096 DEBUG [org.geoserver.config] - Persisted com.sun.proxy.$Proxy35 to global.xml
2015-01-14 11:38:03,101 DEBUG [org.geoserver] - Thread 14 releasing the lock in mode WRITE
2015-01-14 11:38:03,101 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2015-01-14 11:38:03,101 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/xml;charset=UTF-8
2015-01-14 11:38:08,901 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2015-01-14 11:38:08,902 DEBUG [org.geoserver] - Thread 14 locking in mode WRITE
2015-01-14 11:38:08,902 DEBUG [org.geoserver] - Thread 14 got the lock in mode WRITE
2015-01-14 11:38:08,917 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:08,923 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:08,926 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:08,929 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:08,932 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:08,933 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:08,982 DEBUG [org.geoserver] - Thread 14 releasing the lock in mode WRITE
2015-01-14 11:38:08,982 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2015-01-14 11:38:08,985 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2015-01-14 11:38:10,309 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2015-01-14 11:38:10,310 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2015-01-14 11:38:10,311 DEBUG [org.geoserver] - Thread 14 locking in mode WRITE
2015-01-14 11:38:10,311 DEBUG [org.geoserver] - Thread 14 got the lock in mode WRITE
2015-01-14 11:38:10,317 DEBUG [org.geoserver] - Thread 14 releasing the lock in mode WRITE
2015-01-14 11:38:10,317 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2015-01-14 11:38:10,326 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2015-01-14 11:38:10,327 DEBUG [org.geoserver] - Thread 20 locking in mode WRITE
2015-01-14 11:38:10,327 DEBUG [org.geoserver] - Thread 20 got the lock in mode WRITE
2015-01-14 11:38:10,336 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:10,339 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:10,341 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:10,342 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:10,343 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:10,345 DEBUG [org.geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/geoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2015-01-14 11:38:10,391 DEBUG [org.geoserver] - Thread 20 releasing the lock in mode WRITE
2015-01-14 11:38:10,391 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2015-01-14 11:38:10,394 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2015-01-14 11:38:14,689 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2015-01-14 11:38:14,690 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2015-01-14 11:38:14,691 DEBUG [org.geoserver] - Thread 15 locking in mode WRITE
2015-01-14 11:38:14,691 DEBUG [org.geoserver] - Thread 15 got the lock in mode WRITE
2015-01-14 11:38:14,704 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
Sent: Wednesday, January 14, 2015 11:14 AM
To: Bistrais, Bob
Hi Bob,
posting it again with less quotes to avoid “waiting for moderator’s approval due to message too long”
Hi Bob,
did you configure the GDAL_DRIVER_PATH to point to Program Files (x86)\GDAL\gdalplugins ?
Daniele
On Wed, Jan 14, 2015 at 9:12 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Bob,
Daniele
On Tue, Jan 13, 2015 at 8:58 PM, Bistrais, Bob <Bob.Bistrais@anonymised.com.6406…> wrote:
OK, it looks like I needed the MSVC2010 versions. I installed them. But I am still getting the error message.
You also mentioned that I needed to install the external JP2 driver. Is that the drivers found here? http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.10/
I did use the msi installer for MrSID and the ECW, and I see DLL’s for these in Program Files (x86)\GDAL\gdalplugins. Also, when I try to Add New Store, I see the option for JP2K (Direct), but not MrSID. Should I send the log file again?
