Hello,
I need to raise the jpeg quality when using it as output format for WMS. I’m using geoserver 1.6.5 and, to my surprise, when looking around I couldn’t find any way to do this.
Is there a setting for this that I’m not seeing, or is it indeed a missing feature?
/Björn
Ciao Bjorn,
actually, you are right, there is no way to configure this. Default
quality is 75% (visually lossless).
It could be implemented quite easily though, but I guess it is the
kind of the thing that gets procrastined indefinitely unitl someone
really needs it :-).
Simone.
On Fri, Oct 3, 2008 at 6:24 PM, Björn Harrtell <bjorn.harrtell@anonymised.com> wrote:
Hello,
I need to raise the jpeg quality when using it as output format for WMS. I'm
using geoserver 1.6.5 and, to my surprise, when looking around I couldn't
Is there a setting for this that I'm not seeing, or is it indeed a missing
feature?
/Björn
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
Hehe, well I really need it
Seriously though, if this is a very low priority thing, we would like to patch it ourselves. If you could point out the class that we need to tinker with it would be much appriciated.
/Björn
On Fri, Oct 3, 2008 at 6:30 PM, Simone Giannecchini <simboss1@…84…> wrote:
Ciao Bjorn,
Simone.
On Fri, Oct 3, 2008 at 6:24 PM, Björn Harrtell <bjorn.harrtell@…84…> wrote:
Hello,
feature?
/Björn
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
prizes
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Well,
actually, quite a few things would be involved at both the geotools
and geoserver level. It takes more time to explain it than to do it
Thinking...., you might want to track down how the hint to use non
native jpeg writer is implemented through the various layers. When you
get to the ImageWorker class in geotools, I'll tell you how to change
writer settings.
Simone.
On Fri, Oct 3, 2008 at 6:35 PM, Björn Harrtell <bjorn.harrtell@anonymised.com> wrote:
/Björn
On Fri, Oct 3, 2008 at 6:30 PM, Simone Giannecchini <simboss1@anonymised.com>
wrote:
Ciao Bjorn,
Simone.
On Fri, Oct 3, 2008 at 6:24 PM, Björn Harrtell <bjorn.harrtell@anonymised.com.>
wrote:
> Hello,
> I'm
> couldn't
> missing
> feature?
> /Björn
> challenge
> prizes
> world
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hmm first time looking at the gigantic source that makes up geotools and geoserver I don’t understand much of “the hint to use non native jpeg writer is implemented through the various layers.”
But looking at JPEGMapProducer.java line 47:
new ImageWorker(image).writeJPEG(outStream, “JPEG”, 0.75f, JPEGNativeAcc.booleanValue());
Wouldn’t a quick and dirty fix be to adjust the value, recompile and replace?
/Björn
On Fri, Oct 3, 2008 at 6:48 PM, Simone Giannecchini <simboss1@…84…> wrote:
Well,
Thinking…, you might want to track down how the hint to use non
get to the ImageWorker class in geotools, I’ll tell you how to change
writer settings.
Simone.
/Björn
wrote:
Ciao Bjorn,
Simone.
wrote:
Hello,
I’m
couldn’t
missing
feature?
/Björn
challenge
prizes
world
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ciao Bjorn,
if what you are looking for is a quick & dirty fix, what you describe
above would do what you need?
I thought you wanted the capability to this kind of stuff from the UI...
Simone.
On Sat, Oct 4, 2008 at 2:57 PM, Björn Harrtell <bjorn.harrtell@anonymised.com> wrote:
geoserver I don't understand much of "the hint to use non native jpeg writer
is implemented through the various layers."
new ImageWorker(image).writeJPEG(outStream, "JPEG", 0.75f,
Wouldn't a quick and dirty fix be to adjust the value, recompile and
replace?
/Björn
On Fri, Oct 3, 2008 at 6:48 PM, Simone Giannecchini <simboss1@anonymised.com>
wrote:
Well,
writer settings.
Simone.
On Fri, Oct 3, 2008 at 6:35 PM, Björn Harrtell <bjorn.harrtell@anonymised.com.>
> tinker
> /Björn
> wrote:
>> Ciao Bjorn,
>> Simone.
>> wrote:
>> > Hello,
>> > WMS.
>> > I'm
>> > couldn't
>> > missing
>> > feature?
>> > /Björn
>> > challenge
>> > great
>> > prizes
>> > world
>> > _______________________________________________
>> GeoSolutions S.A.S.
>> Via Carignoni 51
>> 55041 Camaiore (LU)
>> Italy
>> fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Doing this the proper way and including in GUI would be nice, but wanted to raise the jpeg quality quickly in a production enviroment.
Perhaps later I’ll be confident enough with the code base to contribute this but for now thanks for confiming the quick fix.
/Björn
On Sun, Oct 5, 2008 at 11:12 PM, Simone Giannecchini <simboss1@…84…> wrote:
Ciao Bjorn,
I thought you wanted the capability to this kind of stuff from the UI…
Simone.
replace?
/Björn
wrote:
Well,
writer settings.
Simone.
tinker
/Björn
wrote:
Ciao Bjorn,
Simone.
wrote:
Hello,
WMS.
I’m
couldn’t
missing
feature?
/Björn
challenge
great
prizes
world
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
