It looks like that certain JPEG2000 file is crashing GDAL. What version of GDAL do you have and which JPEG2000 drivers your version supports? If you can't read image info with GDAL, could it be possible for you to install Kakadu demo programs from http://www.kakadusoftware.com/index.php?option=com_content&task=view&id=26&Itemid=22 and study the image with kdu_show viewer? Through menu item File-Properties you will get useful information.
-Jukka Rahkonen-
GeoGEOrge wrote:
It seems you have identified the area I have not set up correctly.
I unpacked the gdal native to a new directory and ran gdalinfo on one of my
jp2 files:
./gdalinfo A.jp2
terminate called after throwing an instance of 'srd::length_error'
what(): basic_string::S_create
Aborted (core dumped)
which is the same error geoserver spits out before it ceases to function.
I must be missing some basic step.
View this message in context: http://osgeo-org.1560.x6.nabble.com/JPEG2000-
crashed-GeoServer-tp5059217p5060702.html
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
Thank you for your reply. I downloaded a sample .jp2 from here:
http://www.microimages.com/gallery/jp2/CB_TM432.jp2
to see if it was my image that was the problem, but i get the same error.
I have tried it with and without accompanying .xml .prj .j2w files without
success.
I put the .jp2 file in the same directory as the native libraries and ran
gdalinfo from there without success.
View this message in context: http://osgeo-org.1560.x6.nabble.com/JPEG2000-crashed-GeoServer-tp5059217p5060845.html
gdal 1.9.2
gdal192-Ubuntu12-gcc4.6.3-i386.tar.gz
JP2MrSID (rov): MrSID JPEG2000
View this message in context: http://osgeo-org.1560.x6.nabble.com/JPEG2000-crashed-GeoServer-tp5059217p5060848.html
Ciao,
can check the gcc version for us? This looks like a low level error...
Do you also have GDAL somewhere else in the path?
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Tue, Jun 18, 2013 at 1:50 PM, GeoGEOrge <awmlamp@anonymised.com> wrote:
gdal 1.9.2
