[Geoserver-users] JPW and PGW
Dear All,
I am using geoserver with WCS. I have a question to you about *.JPW and
*.PGW files.
I don't understand what ar JPW and PGW files, how create them ?
Anybody can help me please\?
Thanks a lot !
Bui Hong Son
Deputy Chief of SCIREN
http://ciren.vn
http://www2.hcm.ciren.gov.vn/cirengis
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of
geoserver-users-request@lists.sourceforge.net
Sent: Thursday, October 25, 2007 11:43 PM
Subject: Geoserver-users Digest, Vol 17, Issue 53
Send Geoserver-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  geoserver-users-owner@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Geoserver-users digest..."
Today's Topics:
   1. Re: 1.6.3 Beta 3 war in JBoss 4.0.5 (Andy Dale)
   2. Re: How to adjust the tolerance of FeatureInfo-requests?
      (Justin Deoliveira)
   3. Specifying a custom native projection (David R Robison)
   4. Re: Specifying a custom native projection (Justin Deoliveira)
   5. Re: How to adjust the tolerance of FeatureInfo-requests?
      (Gabriel Rold?n)
Message: 1
Date: Thu, 25 Oct 2007 11:36:44 +0200
Subject: Re: [Geoserver-users] 1.6.3 Beta 3 war in JBoss 4.0.5
To: "Andrea Aime" <aaime@anonymised.com>
Message-ID:
  <faa313130710250236k477031ep597793cc9f88e25a@anonymised.com>
Content-Type: text/plain; charset="iso-8859-1"
I have carried out a bit of testing, with a config I know works (
JBoss-4.0.4.GA and geoserver-1.5.1.war) without the data dir being set and
it works fine, but when i try to deploy the 1.6 war i get the same errors as
in the JBoss-4.0.5.GA environment. This leads me to believe that the data
dir is not the cause/solution to the problem.
Andy
On 25/10/2007, Andrea Aime <aaime@anonymised.com> wrote:
Andy Dale ha scritto:
> Hi,
> I am trying to deploy geoserver as a war archive within JBoss-4.0.5.GA
> <http://JBoss-4.0.5.GA>, but unfortunately it will not deploy at all :frowning:
> . The first error that appears is the following :
> 2007-10-25 10:59:23,886 DEBUG [org.jboss.web.tomcat.tc5.TomcatDeployer]
> Using session cookies default setting
> 2007-10-25 10:59:24,396 ERROR [STDERR] log4j:ERROR A
> "org.jboss.logging.util.OnlyOnceErrorHandler" object is not assignable
> to a " org.apache.log4j.spi.Error
> Handler" variable.
> 2007-10-25 10:59:24,397 ERROR [STDERR] log4j:ERROR The class
> "org.apache.log4j.spi.ErrorHandler" was loaded by
> 2007-10-25 10:59:24,397 ERROR [STDERR] log4j:ERROR [WebappClassLoader
> delegate: false
> repositories:
> /WEB-INF/classes/
> ----------> Parent Classloader:
> java.net.FactoryURLClassLoader@anonymised.com
> ] whereas object of type
> 2007-10-25 10:59:24,398 ERROR [STDERR] log4j:ERROR "
> org.jboss.logging.util.OnlyOnceErrorHandler" was loaded by
> [org.jboss.system.server.NoAnnotationURLClass
> Loader@anonymised.com].
> 2007-10-25 10:59:24,532 ERROR [STDERR] log4j:ERROR Could not create an
> Appender. Reported error follows.
> 2007-10-25 10:59:24,532 ERROR [STDERR] java.lang.ClassCastException:
> org.jboss.logging.appender.DailyRollingFileAppender
> 2007-10-25 10:59:24,534 ERROR [STDERR] at
> org.apache.log4j.xml.DOMConfigurator.parseAppender
> (DOMConfigurator.java:175)
> 2007-10-25 10:59:24,535 ERROR [STDERR] at
> org.apache.log4j.xml.DOMConfigurator.findAppenderByName(
DOMConfigurator.java:150)
> org.apache.log4j.xml.DOMConfigurator.findAppenderByReference
> (DOMConfigurator.java:163)
> 2007-10-25 10:59:24,536 ERROR [STDERR] at
> org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(
DOMConfigurator.java:425)
> org.apache.log4j.xml.DOMConfigurator.parseRoot (DOMConfigurator.java
:394)
> org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:829)
> 2007-10-25 10:59:24,537 ERROR [STDERR] at
> org.apache.log4j.xml.DOMConfigurator.doConfigure (DOMConfigurator.java
:712)
> org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java
:618)
> org.apache.log4j.helpers.OptionConverter.selectAndConfigure
> (OptionConverter.java:470)
> 2007-10-25 10:59:24,538 ERROR [STDERR] at
> org.apache.log4j.LogManager.<clinit>(LogManager.java:122)
This one I've never seen, but does not seem to be fatal.
> This then has a knock on effect, and the next exception is:
> Initialization of bean failed; nested exception is
> java.lang.NullPointerException: null
> org.springframework.beans.factory.BeanCreationException: Error creating
> bean with name 'config' defined in URL
> [jar:file:/usr/local/jboss-4.0.5.GA_NO_IMS/se
> rver/default/tmp/deploy/tmp54840geoserver-
> exp.war/WEB-INF/lib/main-1.6-beta3.jar!/applicationContext.xml]:
> s java.lang.NullPointerException: null
> at java.io.FileInputStream .<init>(FileInputStream.java:103)
> at
> org.vfny.geoserver.global.xml.XMLConfigReader.loadServices(
XMLConfigReader.java:241)
> at
> org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java
> :205)
> at
> org.vfny.geoserver.global.xml.XMLConfigReader.<init>(
XMLConfigReader.java:169)
> at
> org.vfny.geoserver.global.Config.setApplicationContext(Config.java:70)
> at
org.springframework.context.support.ApplicationContextAwareProcessor.postPro
cessBeforeInitialization
> (ApplicationContextAwareProcessor.java:84)
> at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory
.applyBeanPostProcessorsBeforeInitialization
(AbstractAutowireCapableB
> eanFactory.java :248)
> at
.createBean
(AbstractAutowireCapableBeanFactory.java:362)
> at
> org.springframework.beans.factory.support.AbstractBeanFactory.getBean
> (AbstractBeanFactory.java:226)
> at
> org.springframework.beans.factory.support.AbstractBeanFactory.getBean(
AbstractBeanFactory.java:147)
> at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolv
eReference
> (BeanDefinitionValueResolver.java:176)
> at
eValueIfNecessary
(BeanDefinitionValueResolver.java:105)
> at
This usually happens when GeoServer war is not unpacked
during deploy. If you don't set the GEOSERVER_DATA_DIR environment
variable GeoServer will try to use the data_dir we ship
inside the war, and fail if the war is not unpacked.
Hope this helps
Message: 2
Date: Thu, 25 Oct 2007 08:26:52 -0700
Subject: Re: [Geoserver-users] How to adjust the tolerance of
To: Andrea Aime <aaime@anonymised.com>
Cc: Tilo W?therich <tilo.wuetherich@anonymised.com>, Mailingliste Geoserver
  <geoserver-users@lists.sourceforge.net>
Message-ID: <4720B5BC.3090807@anonymised.com>
Content-Type: text/plain; charset=us-ascii
+1, sounds like a good way to handle it.
Andrea Aime wrote:
Justin Deoliveira ha scritto:
Hi Tilo,
Currently this is not configurable. but i agree that it would be useful
for the client to be able to specify the size of a buffer. As clicking
on points and lines sometimes can be quite tedious.
Do you want to create a feature request in the issue tracker?
Tilo has created the issue here:
http://jira.codehaus.org/browse/GEOS-1434
Now, I was thinking about it a little and it occurred to me it
has a striking resemblance to the meta-buffer issue.
The meta-buffer is the number of extra pixels we consider around
an image to make sure every feature contributing to the
current map gets rendered for good. When features such as points
have big symbolizers (think a big circle) they do contribute
(partially) to the current map even if their geometry lay outside
of the map bounds. The meta buffer is the measure of the biggest
symbolizer (bigger point, thicker line) used in the map styling.
Now, if you think about it, the size of the ideal getfeatureinfo
search area is exactly the meta-buffer. What's more interesting is
that we already have code to automatically compute the meta buffer
from the map style, so most of the time you would not even need
to provide it manually.
To recap the idea is:
* make GetFeatureInfo use the metabuffer computation code and
   use a search area that matches the biggest symbol size for each
   layer (in fact, half of the symbol size)
* as with GetMap, if the user provides "&buffer=xxx" then use
   it as the search area for GetFeatureInfo.
How does this sound?
!DSPAM:4007,472051e0273333668746562!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Message: 3
Date: Thu, 25 Oct 2007 11:42:59 -0400
Subject: [Geoserver-users] Specifying a custom native projection
To: Mailingliste Geoserver <geoserver-users@lists.sourceforge.net>
Message-ID: <4720B983.8090405@anonymised.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
I have received a shapefile that has a custom projection associated with
it. I loaded it into PostGIS and then linked it to geoserver, however, I
do not know how to indicate what the native SRS WKT is. Can anyone give
me any pointers? Thanks, David Robison
David R Robison
Open Roads Consulting, Inc.
708 S. Battlefield Blvd., Chesapeake, VA 23322
phone: (757) 546-3401
e-mail: drrobison@anonymised.com
web: http://openroadsconsulting.com
blog: http://therobe.blogspot.com
book: http://www.xulonpress.com/book_detail.php?id=2579
Message: 4
Date: Thu, 25 Oct 2007 09:31:32 -0700
Subject: Re: [Geoserver-users] Specifying a custom native projection
To: David R Robison <drrobison@anonymised.com>
Cc: Mailingliste Geoserver <geoserver-users@lists.sourceforge.net>
Message-ID: <4720C4E4.4000409@anonymised.com>
Hi David,
So are you saying that you have the SRS WKT? or that you do not have it
and need a way to figure it out. If its the former you can follow the
instructions here:
http://docs.codehaus.org/display/GEOSDOC/Custom+projection+definition+in+Geo
server+1.5.0+(onwards)
If the latter i am unsure. Reverse engineering the projection of a
shapefile is kind of tough. I will leave that one for the experts.
-Justin
Justin Deoliveira
Message: 5
Date: Thu, 25 Oct 2007 18:43:22 +0200
From: Gabriel Rold?n <gabriel.roldan@anonymised.com>
Cc: Tilo W?therich <tilo.wuetherich@anonymised.com>, Justin Deoliveira
  <jdeolive@anonymised.com>
Message-ID: <200710251843.22599.gabriel.roldan@anonymised.com>
+1 on the metabuffer stuff.
Also, it is not strange that it gets difficult to find a point through
GetFeatureInfo. When sending a GetFeatureInfo from a ui, it gets really
tricky to click on a point near enough to the actual point. See for example
the attached image. Its the result of rendering the same point with a small
circle marker and a bigger triangle marker.
The triangle is never centered at the point location, but its top most
corner
seems to be.
So, I don't quite remember if the SLD spec says nothing about how to locate
a
marker regarding the point location, still it seems quite intuitive (as a
user) to get them centered.
So, should we open an issue against the renderer at all?
Gabriel
>> Hi Tilo,
> Cheers
> Andrea
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Type: image/png
Desc: not available
End of Geoserver-users Digest, Vol 17, Issue 53
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.503 / Virus Database: 269.15.10/1091 - Release Date: 10/24/2007
2:31 PM
No virus found in this outgoing message.
2:31 PM
.jgw and .pgw are so called ESRI World files, short simple text files which are telling the orientation of the corresponding image files. .Jgw is used for jpeg images and .pgw for png images (jpg->jgw and png->pgw, likewise tif->tfw). Search for ESRI World file and you will find some reading from the web.
-Jukka Rahkonen-
From: geoserver-users-bounces@lists.sourceforge.net on behalf of Bui Hong Son
Sent: Fri 26.10.2007 5:34
Subject: [Geoserver-users] JPW and PGW
Dear All,
*.PGW files.
Thanks a lot !
Bui Hong Son
http://ciren.vn
Today's Topics:
      (Justin Deoliveira)
      (Gabriel Rold?n)
Message: 1
Message-ID:
Andy
> Hi,
> Handler" variable.
> delegate: false
> repositories:
> /WEB-INF/classes/
:394)
:712)
:618)
> at
> at
> :205)
> at
> at
> at
> at
> at
.createBean
> at
> at
> at
eReference
> at
eValueIfNecessary
> at
Hope this helps
Message: 2
Hi Tilo,
Justin Deoliveira
Message: 3
David R Robison
Message: 4
Hi David,
instructions here:
-Justin
Justin Deoliveira
Message: 5
corner
seems to be.
a
Gabriel
>> Hi Tilo,
> Cheers
> Andrea
Type: image/png
Desc: not available
2:31 PM
2:31 PM
Thank for your quick reply, Rahkonen Jukka
I used Georeferencing Tool in ESRI ArcMap and I got it .
Bui Hong Son
http://ciren.vn
From: Rahkonen Jukka [mailto:Jukka.Rahkonen@anonymised.com]
Sent: Friday, October 26, 2007 11:28 AM
To: Bui Hong Son; geoserver-users@lists.sourceforge.net
Subject: RE: [Geoserver-users] JPW and PGW
the web.
-Jukka Rahkonen-
Son
Dear All,
*.PGW files.
Thanks a lot !
Bui Hong Son
http://ciren.vn
Today's Topics:
      (Justin Deoliveira)
      (Gabriel Rold?n)
Message: 1
Message-ID:
Andy
> Hi,
> Handler" variable.
> delegate: false
> repositories:
> /WEB-INF/classes/
:394)
:712)
:618)
> at
> at
> :205)
> at
> at
> at
> at
> at
.createBean
> at
> at
> at
eReference
> at
eValueIfNecessary
> at
Hope this helps
Message: 2
Hi Tilo,
Justin Deoliveira
Message: 3
David R Robison
Message: 4
Hi David,
instructions here:
-Justin
Justin Deoliveira
Message: 5
corner
seems to be.
a
Gabriel
>> Hi Tilo,
> Cheers
> Andrea
Type: image/png
Desc: not available
2:31 PM
2:31 PM
Version: 7.5.503 / Virus Database: 269.15.10 - Release Date: 10/24/2007
12:00 AM
Version: 7.5.503 / Virus Database: 269.15.12/1095 - Release Date: 10/26/2007
7:54 PM
