Hi Andrea,
it does look quite a bit similar. I am using 1.6beta4 though.
I've opened up:
http://jira.codehaus.org/browse/GEOS-1481
with a stack trace.
If someone needs more info, let me know.
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Andrea Aime <aaime@anonymised.com>
Naar: Bart van den Eijnden OSGIS <bartvde@anonymised.com>
Cc: geoserver-users@lists.sourceforge.net, Tim Schaub
<tschaub@anonymised.com>
Onderwerp: Re: [Geoserver-users] json output on tables with geometry
Datum: 06/11/07 11:25
Bart van den Eijnden (OSGIS) ha scritto:
> Hi list,
> Geoserver (1.6 beta4) returns a NullPointerException when you try to
get
> outputformat=json for a table/view without a geometry. GML output
works okay
> in this case.
> Is it viable to return GeoJSON in this case without a geometry, i.e.
a
> feature with only attributes?
Looks similar to a fixed issue:
http://jira.codehaus.org/browse/GEOS-1365thought your case is a little different. Care to open a jira issue for
this one?> Does anyone know if the OpenLayers GeoJSON parser will still parse
this?
I have no idea... maybe Tim will know more.
