[Geoserver-users] JVM 1.6.0_06 crash, libjvm.so+0x2641d8
This is a long shot (I did not find anything while searching), but here goes:
Has anyone encountered the following problem while running GeoServer? The question is whether upgrading from 1.6.0_06 is likely to solve the problem.
-Arne
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00002b531412f1d8, pid=4086, tid=1090943296
# Java VM: Java HotSpot(TM) 64-Bit Server VM (10.0-b22 mixed mode linux-amd64)
# Problematic frame:
# V [libjvm.so+0x2641d8]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
We've been having segfault issues on Redhat Enterprise 5 (64bit), JVM 1.6.03, and 1.6.13. Not quite the same crash though:
*** glibc detected *** /usr/local/java/bin/java: free(): invalid pointer: 0x00002aab10946e80 ***
Haven't found a solution yet.
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
-Arne
Geoserver-users mailing list
Did you try export MALLOC_CHECK_=0 ?
http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
-Arne
Mark Leslie
LISAsoft
-Arne
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
No, we haven't. Thanks for the pointer.
-Arne
Mark Leslie
LISAsoft
-Arne
This might help:
http://forums.sun.com/thread.jspa?threadID=5256679
