[Geoserver-users] JVM machine
Good afternoon
Trying to display some maps with Geoserver 1.6.3 on my Tomcat instance, i
have obtained this error message:
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x06188103, pid=1818, tid=2743421872
# Java VM: Java HotSpot(TM) Server VM (1.6.0_01-b06 mixed mode)
# Problematic frame:
# V [libjvm.so+0x188103]
# An error report file with more information is saved as hs_err_pid1818.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Has anyone an idea of what could be the reason of that crash?
It seems not be predictable.
Sylvain
View this message in context: http://www.nabble.com/JVM-machine-tp16850870p16850870.html
Take a look at this doc:
http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
Specifically, this env var: export MALLOC_CHECK_=0 (it cleared up a lot seg
faults problems I was having).
-Frank
springrider wrote:
Good afternoon
hs_err_pid1818.log
Sylvain
View this message in context: http://www.nabble.com/JVM-machine-tp16850870p16862264.html
