[Geoserver-users] kml and TimeStamp
Sébastien Geindre ha scritto:
Justin Deoliveira a écrit :
Hi Sébastien,
I think you will have to use a string format function against the date
to get this to work with the raw value.
${<timstampField>?string("yyyy-MM-ddTHH:mm:ss")}
with ${validity_start_time?string("yyyy-MM-ddTHH:mm:ss")} ,
i have the following error :
22 oct. 15:24:57 ERROR [freemarker.runtime] -
Expected number, date, or string. validity_start_time evaluated instead to freemarker.template.SimpleHash on line 1, column 3 in time.ftl.
The problematic instruction:
==> ${validity_start_time?string("yyyy-MM-ddTHH:mm:ss")} [on line 1, column 1 in time.ftl]
Java backtrace for programmers:
freemarker.template.TemplateException: Expected number, date, or string. validity_start_time evaluated instead to freemarker.template.SimpleHash on line 1, column 3 in time.ftl.
validity_start_time is an attribute, right? So the proper way should
be:
${validity_start_time.rawValue?string("yyyy-MM-ddTHH:mm:ss")}
(I guess)
Let me know
Hi Sébastien,
be:
(I guess)
Let me know
i did try this...
with ${validity_start_time.rawValue?string("yyyy-MM-ddTHH:mm:ss")}
the following one :
22 oct. 15:30:26 ERROR [freemarker.runtime] -
Expression validity_start_time.rawValue is undefined on line 1, column 3 in time.ftl.
==> ${validity_start_time.rawValue?string("yyyy-MM-ddTHH:mm:ss")} [on line 1, column 1 in time.ftl]
freemarker.core.InvalidReferenceException: Expression validity_start_time.rawValue is undefined on line 1, column 3 in time.ftl.
        at freemarker.core.TemplateObject.assertNonNull(TemplateObject.java:124)
        at freemarker.core.TemplateObject.invalidTypeException(TemplateObject.java:134)
Sébastien Geindre
DPREVI/AERO/DEV
sebastien.geindre __at__ meteo.fr
Hi Sébastien,
be:
(I guess)
Let me know
i did try this...
the following one :
Oh hum, this is strange... support for rawValue has been introduced
by Gabriel some days ago while fixing http://jira.codehaus.org/browse/GEOS-1393.
How old is your GeoServer checkout?
Hi Sébastien,
be:
(I guess)
Let me know
i did try this...
the following one :
i did svn update yesterday.
which file could i check ? svn version...
Sébastien Geindre
DPREVI/AERO/DEV
All you have to do is to run svn info
and it'll tell you at which revision you
are (I'm at 7645).
Anyways, this thread is starting to be a bit
long. Any chance you can open a jira issue
for it, and attach to it all the relevant
bits needed to reproduce your problem, that is:
* original data
* templates
* expected vs actual results?
hi Sébastien,
the one doing the trick is org.geoserver.template.FeatureWrapper
please also take a look at FeatureTemplateTest.testRawValue().
You can may be help improve the test case, as I'm not that familiar with the
template syntax.
let us know how it goes.
cheers,
Gabriel
> Cheers
> Andrea
hi Sébastien,
You can may be help improve the test case, as I'm not that familiar with the template syntax.
I played with Junit test on rawValue. It works...
So i tried with adding the version on the depedency of freemarker in main module
        <dependency>
            <groupId>org.freemarker</groupId>
            <artifactId>freemarker</artifactId>
            <version>2.3.9</version>
        </dependency>
and it works !!!
rawValue is ok, i 'll find the right format...
thanks all !
cheers,
Gabriel
Sébastien Geindre
DPREVI/AERO/DEV
       <dependency>
       </dependency>
and it works !!!
We should have no versions declared outside the root pom.xml.
All modules inherit the ones declared there, and we're
already using freemarker 2.3.9 so... this leaves me wondering
why adding the version was necessary at all... ???
