Is there a way to set the number of decimal places that KML vector output uses? The decimal places setting in the Config menu doesn’t seem to affect it. Right now, my KML output only goes to 4 decimal places and therefore looks really jagged.
You can compare the different outputs:
http://client.enplan.com/geos/kmlraster.jpg
http://client.enplan.com/geos/kmlvector.jpg
Marc
n
Marc Pfister
Geospatial Data Manager
ENPLAN
mpfister@anonymised.com647…
530/221-0440 x108
530/221-6963 Fax
This problem has already been fixed and is in the SVN version of Geoserver. You should see the fix in the next release.
Brent Owens
(The Open Planning Project)
Marc
n
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
