On Thu, Aug 27, 2015 at 2:21 AM, Jair Santos <jsantos5954@anonymised.com> wrote:
Hello all,
I know that this is an openlayer code but my question is about Geoserver.
When I create a tile layer I pass the geoserver url like
var wmsSourcePzones = new ol.source.TileWMS({
url: 'http://192.168.1.113:8080/geoserver/wms’,
params: { 'LAYERS': 'pzones' },
serverType: 'geoserver'
What would be the geoserver reference (url) when I create a KML layer?
The URL is the same, it's just a different &format parameter value.
However... KML out of WMS is not exactly the best format
for tiling, you should look at superoverlays instead:
http://docs.geoserver.org/stable/en/user/googleearth/features/kmlsuperoverlays.html
When I click the preview layer in the geoserver admin I am basically
downloading a .KML file. Where is it located in geoserver? Moreover, the
data is in postgis, so how the KML will be available to the client program?
The KML file is generated on the fly from your data and default style for
that layer
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
