[Geoserver-users] KML output based on WFS - Request
Hi @ all,
i am trying to get a kml-file based on a WFS-Request, but it doesn't work:
The Reuest:
http://localhost:8080/geoserver/wfs?
service=WFS
&REQUEST=GetFeature
&version=1.0.0
&TYPENAME=topp:states
*&format=application/vnd.google-earth.kml+XML*
&width=1024
&height=1024
&srs=EPSG:4326
&layers=topp:states
&styles=population
&bbox=-180,-90,180,90
=> I get the Result as a GML-File, am I doing something wrong?
The Requwst based on a WMS-Request worked dir:
http://localhost:8080/geoserver/wms?
service=WMS
&request=GetMap
&version=1.1.1
*&format=application/vnd.google-earth.kml+XML *
&width=1024
&height=1024
&srs=EPSG:4326
&layers=topp:states
&styles=population
Gregor
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
Dipl. Ing. (FH) Gregor Fikoczek
mailto:gregor.fikoczek@anonymised.com
mailto:info@anonymised.com
http://www.wheregroup.com
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRA 6788
Gregor Fikoczek ha scritto:
Hi @ all,
The Reuest:
service=WFS
&REQUEST=GetFeature
&version=1.0.0
&width=1024
&height=1024
&srs=EPSG:4326
&layers=topp:states
&styles=population
Funny you get a request at all, we don't have any KML output
out of WFS. The rationale is that KML is styled output, so it
belongs to WMS (as SVG does).
Thought it would not be that difficult to add the output
to WFS as well, especially if the styling rule was to use
the WMS default style anyways.
If you need this, open a jira issue (jira.codehaus.org).
Hi @ all,
The Reuest:
service=WFS
&REQUEST=GetFeature
&version=1.0.0
&width=1024
&height=1024
&srs=EPSG:4326
&layers=topp:states
&styles=population
Thanks for the quick answer Andrea,
at the moment i will use only the KML output based on WMS.
Greq
Siemensstraße 8
53121 Bonn
Komplementärin:
vertreten durch:
