[Geoserver-users] KML Placemarks not located correct (Geoserver 2.8.1)
Hi All,
I have an issue with the KML Reflector in Geoserver 2.8.1.
Is there any way to get the KML Placemarks to work properly in this instance…
The data is SDE 10.2.2 in Oracle 12c, EPSG:3005….
The raster output displays properly (zoom in as there is scale dependency) and the placemarks are returned but they are not located properly.
http://delivery.openmaps.gov.bc.ca/geo/pub/wms/kml?kmscore=0&mode=refresh&layers=pub:WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG&format_options=kmplacemark:true
any suggestions? Is there a known issue for this?
The superoverlay option isn’t really feasible as we have over 600+ layers that need to be configured, and if we have to specify regionating attributes this could get cumbersome. Or perhaps there is something I am missing.
Many thanks
Michelle
On Sat, Jan 9, 2016 at 1:50 AM, Douville, Michelle R GCPE:EX <
Michelle.Douville@anonymised.com> wrote:
Hi All,
instance…
Can you be more specific about the location error? How big is it, does it
look like a translation?
With a datum change in the middle, from NAD83 to WGS84 (used by Google
Earth), some offset is to be expected, althought
normally between those two is really small.
According to epsg.io the best transformation accuracy would be 4m:
http://epsg.io/3005
If you have some sample points to test, one can check the transformation
made by GeoServer, using
the transformation console (in the demo section) with the proj4 one.
E.g., I've tried a random coordinate in the valid range of EPSG:3005
(according to the epsg.io page),
first using cs2cs (based on libproj4, e.g., the same used by QGis):
cs2cs +init=epsg:3005 +to +init=epsg:4326 -f %2f
1000000 2000000
-126.000000 62.994224 0.000000
and then the same coordinates with the GeoServer reprojection console,
which returns:
-126.0 62.99422426150637
Seems to me there is a very good match with the two tools, does not look
like there is a bug here.
Sometimes a large offset is due to the data being advertised in one CRS,
but actually stored in another.
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
Thank you for your response.
Here is an example of a placemark which isn’t in the right place:
The lookat and the point coordinates are different (I would think they should both be in the lat long range of 49->60-124->-117.
The layer config is listed below after the KML output…
Thanks again!
Michelle
KML PLACEMARK OUTPUT with KML Network Link (mode=refresh, kmscore=0, kmplacemark=true)
Natural Resource Districts Generalized - Colour Themed
<![CDATA[
  • District Name: Cariboo-Chilcotin Natural Resource District
  • Org Unit: DCC
  • Org Unit Name: Cariboo-Chilcotin Natural Resource District
  • Region Org Unit: RCB
  • Region Org Unit Name: Cariboo Natural Resource Region
  • Feature Code: FM90000020
  • Feature Name: Natural Resource District
  • Area Square Meters: 4.93381060054049E10
  • Length Meters: 1715478.6781
-96.60873250800569
-9.849147269320397
0
0
0
0.1
00ffffff 0 ff6e6e6e 0.4 ff4d4fa8 1
gx:balloonVisibility1</gx:balloonVisibility>
32400,32400,0
Layer.xml in Geoserver:
FeatureTypeInfoImpl–4ef8d84c:152139b63b5:-7f72
NamespaceInfoImpl–56fcfc1b:14e20f6b441:-7ffe
Natural Resource (NR) Districts
ArcSDE
text/plain
TC211
http://catalogue.data.gov.bc.ca/dataset/generalized-natural-resource-nr-districts
EPSG:3005
273875.663
1870571.76
362346.895
1735670.856
EPSG:3005
-142.68590291964242
-106.84575896667096
36.17884878108903
72.01899273406049
EPSG:4326
FORCE_DECLARED
true
SHAPE
false
geometry
DataStoreInfoImpl-ffe839e:15169916d99:-7ffe
0
0
false
false
false
On Sat, Jan 9, 2016 at 1:50 AM, Douville, Michelle R GCPE:EX <Michelle.Douville@…2145…> wrote:
Hi All,
Can you be more specific about the location error? How big is it, does it look like a translation?
With a datum change in the middle, from NAD83 to WGS84 (used by Google Earth), some offset is to be expected, althought
http://epsg.io/3005
If you have some sample points to test, one can check the transformation made by GeoServer, using
E.g., I’ve tried a random coordinate in the valid range of EPSG:3005 (according to the epsg.io page),
1000000 2000000
and then the same coordinates with the GeoServer reprojection console, which returns:
Seems to me there is a very good match with the two tools, does not look like there is a bug here.
Sometimes a large offset is due to the data being advertised in one CRS, but actually stored in another.
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
hum weird, it almost seems the coordinates for the point have not been reprojected.
Can you share a bit of the source data and the WMS request generating the KML
as a new bug report at https://osgeo-org.atlassian.net/projects/GEOS/summary ?
On Sat, Jan 9, 2016 at 6:41 PM, Douville, Michelle R GCPE:EX <Michelle.Douville@anonymised.com> wrote:
Hi Andrea,
Thanks again!
Michelle
<![CDATA[
  • Org Unit: DCC
-96.60873250800569
-9.849147269320397
0
0
0
0.1
32400,32400,0
ArcSDE
text/plain
TC211
EPSG:3005
273875.663
1870571.76
362346.895
1735670.856
EPSG:3005
-142.68590291964242
-106.84575896667096
36.17884878108903
72.01899273406049
EPSG:4326
FORCE_DECLARED
true
SHAPE
false
geometry
0
0
false
false
false
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Saturday, January 9, 2016 1:07 AM
To: Douville, Michelle R GCPE:EX
Subject: Re: [Geoserver-users] KML Placemarks not located correct (Geoserver 2.8.1)
On Sat, Jan 9, 2016 at 1:50 AM, Douville, Michelle R GCPE:EX <Michelle.Douville@anonymised.com> wrote:
Hi All,
http://epsg.io/3005
1000000 2000000
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Andrea
I will proceed with that. The data is oracle Spatial type (SDO) registered with SDE. I can share the data, but I am not sure which output/dump type you would prefer. I thought perhaps I may try the oracle driver and skip SDE and see what that does.
Thanks.
Michelle
On 9 Jan 2016 9:57 a.m., Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Jan 9, 2016 at 6:41 PM, Douville, Michelle R GCPE:EX <Michelle.Douville@anonymised.com<mailto:Michelle.Douville@anonymised.com>> wrote:
Hi Andrea,
The layer config is listed below after the KML output..
Thanks again!
Michelle
<kml xmlns="http://www.opengis.net/kml/2.2&quot; xmlns:gx="http://www.google.com/kml/ext/2.2&quot; xmlns:kml="http://www.opengis.net/kml/2.2&quot; xmlns:atom="http://www.w3.org/2005/Atom&quot;&gt;
<Placemark id="WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG.24">
      <name>Natural Resource Districts Generalized - Colour Themed</name>
      <description><![CDATA[<ul>
<li><b>District Name</b>: Cariboo-Chilcotin Natural Resource District</li>
<li><b>Org Unit</b>: DCC</li>
<li><b>Org Unit Name</b>: Cariboo-Chilcotin Natural Resource District</li>
<li><b>Region Org Unit</b>: RCB</li>
<li><b>Region Org Unit Name</b>: Cariboo Natural Resource Region</li>
<li><b>Feature Code</b>: FM90000020</li>
<li><b>Feature Name</b>: Natural Resource District</li>
<li><b>Area Square Meters</b>: 4.93381060054049E10</li>
<li><b>Length Meters</b>: 1715478.6781</li>
</ul>]]></description>
      <LookAt>
            <longitude>-96.60873250800569</longitude>
            <latitude>-9.849147269320397</latitude>
            <altitude>0</altitude>
            <heading>0</heading>
            <tilt>0</tilt>
            <range>0.1</range>
      </LookAt>
      <Style>
            <LabelStyle>
                  <color>00ffffff</color>
                  <scale>0</scale>
            </LabelStyle>
            <LineStyle>
                  <color>ff6e6e6e</color>
                  <width>0.4</width>
            </LineStyle>
            <PolyStyle>
                  <color>ff4d4fa8</color>
                  <outline>1</outline>
            </PolyStyle>
      </Style>
      <gx:balloonVisibility>1</gx:balloonVisibility>
      <Point>
            <coordinates>32400,32400,0</coordinates>
      </Point>
</Placemark>
</kml>
<featureType>
  <id>FeatureTypeInfoImpl--4ef8d84c:152139b63b5:-7f72</id>
  <name>WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG</name>
  <nativeName>WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG</nativeName>
  <namespace>
    <id>NamespaceInfoImpl--56fcfc1b:14e20f6b441:-7ffe</id>
  </namespace>
  <title>Natural Resource (NR) Districts</title>
  <keywords>
    <string>ArcSDE</string>
    <string>WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG</string>
  </keywords>
  <metadataLinks>
    <metadataLink>
      <type>text/plain</type>
      <metadataType>TC211</metadataType>
      <content>http://catalogue.data.gov.bc.ca/dataset/generalized-natural-resource-nr-districts&lt;/content&gt;
    </metadataLink>
  </metadataLinks>
  <srs>EPSG:3005</srs>
  <nativeBoundingBox>
    <minx>273875.663</minx>
    <maxx>1870571.76</maxx>
    <miny>362346.895</miny>
    <maxy>1735670.856</maxy>
    <crs class="projected">EPSG:3005</crs>
  </nativeBoundingBox>
  <latLonBoundingBox>
    <minx>-142.68590291964242</minx>
    <maxx>-106.84575896667096</maxx>
    <miny>36.17884878108903</miny>
    <maxy>72.01899273406049</maxy>
    <crs>EPSG:4326</crs>
  </latLonBoundingBox>
  <projectionPolicy>FORCE_DECLARED</projectionPolicy>
  <enabled>true</enabled>
  <metadata>
    <entry key="kml.regionateAttribute">SHAPE</entry>
    <entry key="cachingEnabled">false</entry>
    <entry key="kml.regionateStrategy">geometry</entry>
  </metadata>
  <store class="dataStore">
    <id>DataStoreInfoImpl-ffe839e:15169916d99:-7ffe</id>
  </store>
  <maxFeatures>0</maxFeatures>
  <numDecimals>0</numDecimals>
  <overridingServiceSRS>false</overridingServiceSRS>
  <skipNumberMatched>false</skipNumberMatched>
  <circularArcPresent>false</circularArcPresent>
</featureType>
From: andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com> [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Cc: geoserver-users@lists.sourceforge.net<mailto:geoserver-users@anonymised.comceforge.net>
On Sat, Jan 9, 2016 at 1:50 AM, Douville, Michelle R GCPE:EX <Michelle.Douville@anonymised.com<mailto:Michelle.Douville@anonymised.com>> wrote:
Hi All,
According to epsg.io<http://epsg.io> the best transformation accuracy would be 4m:
http://epsg.io/3005
E.g., I've tried a random coordinate in the valid range of EPSG:3005 (according to the epsg.io<http://epsg.io> page),
1000000 2000000
Ing. Andrea Aime
@geowolf
Technical Lead
phone: +39 0584 962313<tel:%2B39%200584%20962313>
fax: +39 0584 1660272<tel:%2B39%200584%201660272>
mob: +39 339 8844549<tel:%2B39%20%C2%A0339%208844549>
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Jan 9, 2016 at 7:07 PM, Douville, Michelle R GCPE:EX <
Thanks Andrea
Yep, that's a good idea, I don't have a SDE instance to perform tests.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea
I have created this https://osgeo-org.atlassian.net/browse/GEOS-7369
And have switch to a ORACLE NG driver for the same data (skipping SDE registration) .
And I looks to be the same issue for the KML output for that.
Interesting to note, that I could not compute bounds (native or latlong) unless I explicitly set the schema.
For this test, when I explicity set the schema in the datastore, I was able to compute the bounds no problem.
(if I switch to Oracle drivers I am hoping to leave schema blank).
Oracle driver KML Placemark test failed, request and response (switched from SDE driver for same SDO data):
GET http://delivery.openmaps.gov.bc.ca/geo/test/wms?service=wms&request=GetMap&version=1.1.1&format=application/vnd.google-earth.kml+xml&layers=test:WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG&styles=polygon&height=2048&width=2048&transparent=false&srs=EPSG:4326&format_options=AUTOFIT:true;KMATTR:true;KMPLACEMARK:true;KMSCORE:0;MODE:refresh;SUPEROVERLAY:false&BBOX=168.5532288763974,31.7126716688352,291.2419605711542,68.12584606065629 HTTP/1.1
Host: delivery.openmaps.gov.bc.ca
Connection: keep-alive
Accept: application/vnd.google-earth.kml+xml, application/vnd.google-earth.kmz, image/*, /
User-Agent: GoogleEarth/7.1.5.1557(Windows;Microsoft Windows (6.1.7601.1);en;kml:2.2;client:Free;type:default)
Accept-Encoding: gzip,deflate
Accept-Language: en-us,en,*
Accept-Charset: iso-8859-1,*,utf-8
Cookie: GS_FLOW_CONTROL=“GS_CFLOW_f110b0:152296ae8b9:-7ff6”
HTTP/1.1 200 OK
Server: Apache-Coyote/1.1
X-Control-flow-delay-ms: 0
Content-Disposition: attachment; filename=test-WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG.kml
Content-Type: application/vnd.google-earth.kml+xml
Set-Cookie: GS_FLOW_CONTROL=“GS_CFLOW_f110b0:152296ae8b9:-7ff6”; Version=1
Access-Control-Allow-Methods: OPTIONS,GET,POST
Access-Control-Allow-Headers: X-Requested-With, Referer, Origin, Content-Type
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
Content-Length: 78644
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
-165.6761067729959
63.61249441022324
9217374.662677778
0.0
0.0
7448122.1941406075
clampToGround
-114.80358157237526
45.40233389539659
1.0372488476100594E7
0.0
0.0
8381514.74303516
clampToGround
0
http://delivery.openmaps.gov.bc.ca/geo/test/wms?service=wms&amp;request=GetMap&amp;version=1.1.1&amp;format=image%2Fpng&amp;layers=test%3AWHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG&amp;styles=polygon&amp;height=608&amp;width=2048&amp;transparent=true&amp;bbox=168.5532288763974%2C31.7126716688352%2C291.2419605711542%2C68.12584606065629&amp;srs=EPSG%3A4326&amp;format_options=AUTOFIT%3Atrue%3BKMATTR%3Atrue%3BKMPLACEMARK%3Atrue%3BKMSCORE%3A0%3BMODE%3Arefresh%3BSUPEROVERLAY%3Afalse
0.0
never
0.0
0.75
0.0
68.12584606065629
31.7126716688352
168.5532288763974
291.2419605711542
0.0
WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG.North Island - Central Coast Natural Resource District
<h4>WHSE_ADMIN_BOUNDARIES.ADM_NR_DISTRICTS_SPG</h4>
<ul class="textattributes">
<li><strong><span class="atr-name">ORG_UNIT</span>:</strong> <span class="atr-value">DNI</span></li>
<li><strong><span class="atr-name">ORG_UNIT_NAME</span>:</strong> <span class="atr-value">North Island - Central Coast Natural Resource District</span></li>
<li><strong><span class="atr-name">REGION_ORG_UNIT</span>:</strong> <span class="atr-value">RWC</span></li>
<li><strong><span class="atr-name">REGION_ORG_UNIT_NAME</span>:</strong> <span class="atr-value">West Coast Natural Resource Region</span></li>
<li><strong><span class="atr-name">FEATURE_CODE</span>:</strong> <span class="atr-value">FM90000020</span></li>
<li><strong><span class="atr-name">FEATURE_NAME</span>:</strong> <span class="atr-value">Natural Resource District</span></li>
<li><strong><span class="atr-name">OBJECTID</span>:</strong> <span class="atr-value">1</span></li>
<li><strong><span class="atr-name">FEATURE_AREA_SQM</span>:</strong> <span class="atr-value">74999697249.8015</span></li>
<li><strong><span class="atr-name">FEATURE_LENGTH_M</span>:</strong> <span class="atr-value">1933321.1904</span></li>
</ul>
84.97408885837622
68.87518962642825
0.0
0.0
0.0
0.0
clampToGround
00ffffff 0.0 ff000000 1.0 ffaaaaaa 1
905124.9740888583,737348.8751896265
On Sat, Jan 9, 2016 at 7:07 PM, Douville, Michelle R GCPE:EX <Michelle.Douville@…2145…> wrote:
Thanks Andrea
Yep, that’s a good idea, I don’t have a SDE instance to perform tests.
Ing. Andrea Aime
@geowolf
Technical Lead
