[Geoserver-users] KML problem when zoomin in
Sorry the second link should have been:
http://www.osgis.nl/download/geoserver_afterzoomin.jpg
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Bart van den Eijnden OSGIS <bartvde@anonymised.com>
Naar: geoserver-users@lists.sourceforge.net
<geoserver-users@lists.sourceforge.net>
Onderwerp: [Geoserver-users] KML problem when zoomin in
Datum: 07/11/06 12:26
Hi list,
when zooming in very deeply in Google Earth we get a strange phenomenon
with
the kml_reflect script. When zooming in quite far, we get a very
&quot;rugged&quot;
outline of the polygons. Did anybody else notice it and is there a
solution?
http://www.osgis.nl/download/geoserver_beforezoomin.jpg
Thanks in advance.
Best regards,
Bart
http://www.osgis.nl
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&amp;kid=120709&amp;bid=263057&amp;dat=121642
Geoserver-users mailing list
This is probably due to the number of decimal places returned.
We fixed it a couple versions ago so that if you set Config -> Server ->
Number of Decimals then KML as well as GML output will pick that up. So
try increasing the number of decimals there, and I believe it should be
smoother when zoomed in, as it won't round them off.
best regards,
Chris
Best regards,
Bart
http://www.osgis.nl
Hi list,
with
&quot;rugged&quot;
solution?
Thanks in advance.
Best regards,
Bart
http://www.osgis.nl
security? Get stuff done quickly with pre-integrated technology to make
your job
easier
Geronimo
;dat=121642
your job easier Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
!DSPAM:1003,45509e18324727785049143!
