On Thu, Apr 23, 2015 at 8:49 PM, Danny Cheng <dcheng@anonymised.com>
wrote:
The default parameters in a KML reflector request has the format set to
KMZ, but I am actually getting back KML. Is anyone aware of this behaviour?
Or is KML reflector behaving as expected and the document needs to be
updated?
http://docs.geoserver.org/2.6.x/en/user/googleearth/features/kmlreflector.html
I remember there were significant inconsistencies between documented and
actual behavior in the reflector, but don't know which one is the "right"
behavior.
I'd amend the docs to follow what the code does, assuming it's possible to
ask for KMZ, and that it's just the default that's different than documented
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
