I’ve run in to an issue with a long list of layer names being passed to the KML reflector (the URL is about 2000 characters long with all the layer names). I keep getting a response “Failed – Path too long”. I couldn’t find any docs on the the path limit, does anyone know if there is a hard limit?
I did update the maxHeaderSize in tomcat to 64k, but it keeps failing. Does anyone know if there’s a way to just pull all the layers for a workspace without passing a list of layers? Would this work with POST?
Wayne
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today: http://p.sf.net/sfu/appdyn_d2d_mar
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
