[Geoserver-users] KML Requests do not seem to handle multiple SLD rules gracefully
first, see the layer in openlayers:
http://transit.frumin.net:8080/geoserver/wms?bbox=-74.03379402160647,40.61547508239742,-73.87778892517093,40.837611770629884&styles=&Format=application/openlayers&request=GetMap&layers=frumin:trx_stations&width=436&height=550&srs=EPSG:4326
notice as you zoom in the labels change from just the transfers, when they exist, to full station labels. there are different Rules in the SLD for different zoom levels.
now check out the KML:
http://transit.frumin.net:8080/geoserver/wms/kml_reflect?layers=frumin:trx_stations&KMATTR=false
It seems to use both of the rules when generating the labels, so stations that have transfers have both the label, and the transfers displayed. eg: "Jackson Hts-Roosevelt Ave (7,E,F,R,V,X) 7,E,F,R,V"
Should there be more parameters, eg LabelRule, LegendRule, etc., to help specify which Rules to use in rendering?
this is not to mention the legend which shows lots of funkiness.
thoughts? recommendations/
thanks,
mike
Hi Mike,
Currently our kml support pretty much ignores scale... :(. I guess maybe
because you don't really know the resulting image size like you do in
normal wms requests. Perhaps we could just choose a good default
value... not sure.
I am opening a jira issue on this task regardless.
http://jira.codehaus.org/browse/GEOS-1152
-Justin
<http://transit.frumin.net:8080/geoserver/wms?bbox=-74.03379402160647,40.61547508239742,-73.87778892517093,40.837611770629884&styles=&Format=application/openlayers&request=GetMap&layers=frumin:trx_stations&width=436&height=550&srs=EPSG:4326&gt;
<http://transit.frumin.net:8080/geoserver/wms/kml_reflect?layers=frumin:trx_stations&KMATTR=false&gt;
thanks,
mike
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
!DSPAM:4007,4672c6a9115327082231907!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
