[Geoserver-users] KML - Shape to Google Earth exception.
· MapServer on Ubuntu 4.3.2 with java version "1.5.0_16"
· Google Earth 5.0.11337.1968 (beta)
See some of my data in Google Earth before the following exception occurs:
66964 [main] INFO org.mortbay.log - Started
SelectChannelConnector@anonymised.com:8080
72780 [btpool0-4] INFO /geoserver - Initializing Spring FrameworkServlet
'dispatcher'
24 abr 15:10:22 WARN [geoserver.kml] - Error occured processing
'description' template.
java.lang.RuntimeException: org.geoserver.ows.ClientStreamAbortedException
        at
org.geotools.xml.transform.TransformerBase$TranslatorSupport.chars(TransformerBase.java:541)
        at
org.geotools.xml.transform.TransformerBase$TranslatorSupport.cdata(TransformerBase.java:560)
        at
org.vfny.geoserver.wms.responses.map.kml.KMLMapTransformer$KMLMapTranslatorSupport.encodePlacemarkDescription(KMLMapTransformer.java:272)
        at
org.vfny.geoserver.wms.responses.map.kml.KMLMapTransformer$KMLMapTranslatorSupport.encodePlacemark(KMLMapTransformer.java:844)
        at
org.vfny.geoserver.wms.responses.map.kml.KMLMapTransformer$KMLMapTranslatorSupport.encodePlacemark(KMLMapTransformer.java:808)
        at
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:202)
        at
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:144)
        at
org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:203)
        at
org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:133)
        at
org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
        at
org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
        at
org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
        at
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
        at
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
        at
org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:123)
        at
org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:619)
        at
org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:711)
        at
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
        at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
        at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
        at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
        at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
        at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
        at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at
        at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
        at
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at
        at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
        at
        at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
        at
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
        at
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
        at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
        at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
        at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
        at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
        at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
        at org.mortbay.jetty.Server.handle(Server.java:324)
        at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
        at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
        at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: org.geoserver.ows.ClientStreamAbortedException
        at org.apache.xml.serializer.ToStream.cdata(ToStream.java:1246)
        at org.apache.xml.serializer.ToStream.characters(ToStream.java:1351)
        at
org.apache.xalan.transformer.TransformerIdentityImpl.characters(TransformerIdentityImpl.java:1125)
        at
org.geotools.xml.transform.TransformerBase$TranslatorSupport.chars(TransformerBase.java:539)
        ... 67 more
24 abr 15:10:22 ERROR [geoserver.ows] -
java.io.IOException
View this message in context: http://www.nabble.com/KML---Shape-to-Google-Earth-exception.-tp23216505p23216505.html
MapServer? :wink:
'dispatcher'
Don't worry about it, it's just the client abruptly closing the
connection while GeoServer is still sending data, you probably
changed zoom level and GE decided to stop a previous read
it was doing the hard way.
In 1.7.4 these error should not show up anymore in the logs (they
will still be there, just logged at a higher debug level).
Andrea Aime
OpenGeo - http://opengeo.org
