[Geoserver-users] KML styling loses SLD settings?
Is it just me, or does the SLD styling description not carry over to KML
once Geoserver switches to outputting vector geometry?
For example, the parcels shown below have red outlines, which turn white
once you zoom in close enough to trip the KMScore.
http://geoserver.enplan.com/geoserver/wms/kml_reflect?layers=parcels
The SLD is a bare-bones as can be:
<StyledLayerDescriptor version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/sld
StyledLayerDescriptor.xsd"
  xmlns="http://www.opengis.net/sld&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:xlink="http://www.w3.org/1999/xlink&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
<NamedLayer>
    <Name>parcels</Name>
    <UserStyle>
      <Name>parcels_style</Name>
      <Title>geoserver style</Title>
      <Abstract>Generated by GeoServer</Abstract>
      <FeatureTypeStyle>
      <Rule>
        <PolygonSymbolizer>
          <Fill>
            <CssParameter
name="fill">#FFFFFF</CssParameter>
            <CssParameter
name="fill-opacity">0</CssParameter>
          </Fill>
          <Stroke>
            <CssParameter
name="stroke">#FF0000</CssParameter>
            <CssParameter
name="stroke-opacity">1</CssParameter>
          </Stroke>
        </PolygonSymbolizer>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
I checked the list archives for a mention of this and couldn't find
anything. If it's functionality that hasn't been done yet, I can look at
the code to see if it's within my skills to program.
Marc Pfister
Geospatial Data Manager
ENPLAN
mpfister@anonymised.com
530/221-0440 x108
530/221-6963 Fax
I will be taking a look at the KML early next week and will check out this issue. I haven't run across this problem but I will use your SLD to test.
Brent Owens
(The Open Planning Project)
<NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
        <PolygonSymbolizer>
          <Fill>
            <CssParameter
            <CssParameter
          </Fill>
          <Stroke>
            <CssParameter
            <CssParameter
          </Stroke>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
hi,
its the same here. doesnt matter which stroke-width i use in my sld file, it
seems that
in the kml output they are always generated as stroke-width "2". i want to
draw a line with an outline, it
works if im gona request raster data from the wms, the line is drawn
correctly, with the outline.
in Google Earth its just a red line with this sld:
<?xml version="1.0" encoding="ISO-8859-1"?>
    xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
  <NamedLayer>
    <Name>Default Line</Name>
    <UserStyle>
      <Title>A boring default style</Title>
      <Abstract>A sample style that just prints out a green line</Abstract>
      <FeatureTypeStyle>
      <Rule>
          <Name>Rule 2</Name>
          <Title>Outlined Highways</Title>
        <Abstract>A gray outline and white fill, with a 8 pixel width</Abstract>
          <LineSymbolizer>
            <Stroke>
              <CssParameter name="stroke">#000000</CssParameter>
              <CssParameter name="stroke-width">
              <ogc:Literal>7</ogc:Literal>
              </CssParameter>
            </Stroke>
          </LineSymbolizer>
          <LineSymbolizer>
            <Stroke>
              <CssParameter name="stroke">#FF0000</CssParameter>
              <ogc:Literal>3</ogc:Literal>
              </CssParameter>
            </Stroke>
          </LineSymbolizer>
          <TextSymbolizer>
            <Label>
              <ogc:PropertyName>ROUTE_NUM</ogc:PropertyName>
          </Label>
            <Font>
                <CssParameter name="font-family">Times New
Roman</CssParameter>
                <CssParameter name="font-style">Normal</CssParameter>
                <CssParameter name="font-size">14</CssParameter>
            </Font>
            <Fill>
              <CssParameter name="fill-opacity">0</CssParameter>
            </Fill>
                                      </TextSymbolizer>
          <PointSymbolizer>
          <Graphic>
                        <ExternalGraphic>
                                <OnlineResource
xlink:href="http://localhost/transparent.png&quot;/&gt;
                                <Format>image/png</Format>
                        </ExternalGraphic>
                        <Size>23</Size>
                </Graphic>
      </PointSymbolizer>
        </Rule>
        </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
<NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
        <PolygonSymbolizer>
          <Fill>
            <CssParameter
            <CssParameter
          </Fill>
          <Stroke>
            <CssParameter
            <CssParameter
          </Stroke>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
easier
View this message in context: http://www.nabble.com/KML-styling-loses-SLD-settings--tf2093487.html#a6677829
Currently google earth will only render the one line style, even if you supply two of them.
Both are specified in the KML output that geoserver generates, but it is up to GE to render them and it just renders the last one. The only way around it is to have two datasets or to have the KML output as a raster image.
Just set the KMSCORE parameter of the request URL to zero:
KMSCORE=0
This will return you KML that contains a raster image of the data, and you will get your double line styling that way.
Brent Owens
wrobel wrote:
hi,
seems that
<StyledLayerDescriptor version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd" xmlns="http://www.opengis.net/sld&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
  <NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
          <Name>Rule 2</Name>
          <LineSymbolizer>
            <Stroke>
              </CssParameter>
            </Stroke>
          </LineSymbolizer>
          <LineSymbolizer>
            <Stroke>
              </CssParameter>
            </Stroke>
          </LineSymbolizer>
          <TextSymbolizer>
            <Label>
          </Label>
            <Font>
            </Font>
            <Fill>
            </Fill>
                                      </TextSymbolizer>
          <PointSymbolizer>
          <Graphic>
                        <ExternalGraphic>
                                <OnlineResource
                        </ExternalGraphic>
                        <Size>23</Size>
                </Graphic>
      </PointSymbolizer>
        </Rule>
        </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
<NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
        <PolygonSymbolizer>
          <Fill>
            <CssParameter
            <CssParameter
          </Fill>
          <Stroke>
            <CssParameter
            <CssParameter
          </Stroke>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
easier
Theoretically I think you could also just have two styles on one dataset, one the outline and one the inner part, and request them in the right order so the outline is below the inner. But I'm not sure if that works in practice - but it should have geoserver generate the equivalent of two datasets for KML.
Chris
KMSCORE=0
Brent Owens
wrobel wrote:
hi,
seems that
  <NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
          <Name>Rule 2</Name>
          <LineSymbolizer>
            <Stroke>
              </CssParameter>
            </Stroke>
          </LineSymbolizer>
          <LineSymbolizer>
            <Stroke>
              </CssParameter>
            </Stroke>
          </LineSymbolizer>
          <TextSymbolizer>
            <Label>
          </Label>
            <Font>
            </Font>
            <Fill>
            </Fill>
                                      </TextSymbolizer>
          <PointSymbolizer>
          <Graphic>
                        <ExternalGraphic>
                                <OnlineResource
                        </ExternalGraphic>
                        <Size>23</Size>
                </Graphic>
      </PointSymbolizer>
        </Rule>
        </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
<NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
        <PolygonSymbolizer>
          <Fill>
            <CssParameter
            <CssParameter
          </Fill>
          <Stroke>
            <CssParameter
            <CssParameter
          </Stroke>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
easier
opinions on IT & business topics through brief surveys -- and earn cash
!DSPAM:1003,45268cdb148372207481331!
Chris Holmes
http://topp.openplans.org
We serve up relatively simple shapefiles and I haven't added or changed
anything to the server since I installed 1.3.3a about two or three months
ago.
Today, I tried to add a shapefile store and clicked on the apply button. All
fine. I clicked on the save button and boom, this error:
HTTP ERROR: 500 Internal Server Error
RequestURI=/geoserver/admin/saveToXML.do
Since then, I've upgraded the server to 1.4.4a and get the same error. All
the older maps are being served without any problems. But if I try and save
an edit to them, I get the same problem.
This is kinda urgent. Help anyone?
Maurice Tamman
(941) 925-8796; (941) 539-1580(mobile)
maurice.ben@anonymised.com
hi,
i've tested a filter in the sld like :
<Rule>...
<ogc:Filter>
            <ogc:PropertyIsEqualTo>
              <ogc:PropertyName>column</ogc:PropertyName>
              <ogc:Literal>value</ogc:Literal>
            </ogc:PropertyIsEqualTo>
          </ogc:Filter>
</Rule>
<Rule>...
<ogc:Not>
  </ogc:Not>
</ogc:Filter>
</Rule>
in normal raster wms output it works, in GE(kml) it doesnt. I just want to
tell you
this issue.
test.
Brent Owens
<NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
        <PolygonSymbolizer>
          <Fill>
            <CssParameter
            <CssParameter
          </Fill>
          <Stroke>
            <CssParameter
            <CssParameter
          </Stroke>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
easier
Geronimo
easier
View this message in context: http://www.nabble.com/KML-styling-loses-SLD-settings--tf2093487.html#a6717635
hmm, interesting.
I haven't had any issues with filters through testing, and it uses essentially the same filter code as WMS. I will take a deeper look into it. Thanks for reporting it.
Brent Owens
wrobel wrote:
hi,
<Rule>...
<ogc:Filter>
          </ogc:Filter>
</Rule>
<Rule>...
<ogc:Not>
  </ogc:Not>
</ogc:Filter>
</Rule>
tell you
this issue.
Brent Owens
<NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
        <PolygonSymbolizer>
          <Fill>
            <CssParameter
            <CssParameter
          </Fill>
          <Stroke>
            <CssParameter
            <CssParameter
          </Stroke>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
easier
Geronimo
easier
hi,
i altered the filter and now it works. before it looked so :
<Rule>
<ogc:Filter>
  <ogc:Not>
            <ogc:Literal>null</ogc:Literal>
  </ogc:Not>
</ogc:Filter>
</Rule>
now it looks like :
<Rule>
<ogc:Filter>
  <ogc:Not>
    <ogc:PropertyIsNull>
    </ogc:PropertyIsNull>
  </ogc:Not>
</ogc:Filter>
</Rule>
in these rules textsymbolizer should not be set, so values with null
shouldnt be displayed.
strange about it... with first filter the "null" value wasnt displayed in
wms raster output but in
Google Earth. Using the second Filter brings the result for Google Earth.
Brent Owens wrote:
hmm, interesting.
Brent Owens
wrobel wrote:
hi,
<Rule>...
<ogc:Filter>
          </ogc:Filter>
</Rule>
<Rule>...
<ogc:Not>
  </ogc:Not>
</ogc:Filter>
</Rule>
to
tell you
this issue.
test.
Brent Owens
KML
white
<NamedLayer>
    <UserStyle>
      <FeatureTypeStyle>
      <Rule>
        <PolygonSymbolizer>
          <Fill>
            <CssParameter
            <CssParameter
          </Fill>
          <Stroke>
            <CssParameter
            <CssParameter
          </Stroke>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
at
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
security?
easier
Geronimo
security?
easier
Geronimo
your
View this message in context: http://www.nabble.com/KML-styling-loses-SLD-settings--tf2093487.html#a6734631
This error is most likely write permissions to the data directory where your catalog.xml file lives.
Are you using tomcat or jetty to run geoserver?
Brent Owens
ago.
Maurice Tamman
