i got a question about kmz and the Linux Client of GoogleEarth.
At home i got a Slackware 11 Box and at work i’ve installed a SUSE 10.0.
On both Systems fetching the kmz data from a network link end with an error message
Fetching Network Link…
…" no element found"
It is the newest version of GE. On Windows the NetworkLinks works fine with geoserver.
Anyone got an idea about that?
I just tried it on my Gentoo install and it worked ok. What version of
GeoServer are you using? Also what is the network link you are using?
-Justin
jan wrobel wrote:
At home i got a Slackware 11 Box and at work i've installed a SUSE 10.0.
error message
Fetching Network Link...
..." no element found"
with geoserver.
opinions on IT & business topics through brief surveys-and earn cash http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
-Justin
jan wrobel wrote:
error message
with geoserver.
-Justin
jan wrobel wrote:
> Hi,
10.0.
> error message
> with geoserver.
> Regards,
> Jan
-Justin
jan wrobel wrote:
10.0.
error message
with geoserver.
Jan
Join SourceForge.net 's Techsay panel and you’ll get the chance to
share your
Cool, there are some instructions at the bottom of the page describing
how to add a FAQ entry. And there seems to already be a section for KML.
You could just add it under there.
Thanks!!
-Justin
jan wrobel wrote:
Hi Justin,
I've never done that before, but at weekend i will do my best .
jan wrobel wrote:
> Hi,
> ...Now i know the problem. Its not the data or a problem with the kmz
> format.
> The GoogleEarth Client on Linux sends another Client identifier. i
dont
> know where the sense should be by doing so.
> That was the problem, im looking up the Client identifier to prevent
> from "taking" data with the browser for example.
> By a fluke a found that thing, cause i never thought GE will do
> so...sending the identifier in dependence of the OS.
> Regards,
> Jan
> 2007/2/22, Justin Deoliveira <jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com>
> <mailto:jdeolive@anonymised.com >>:
> Hi Jan,
version of
using?
> -Justin
> jan wrobel wrote:
> > Hi,
a SUSE
> 10.0.
end with an
> > error message
works fine
> > with geoserver.
> > Regards,
> > Jan
> > Join SourceForge.net 's Techsay panel and you'll get the
chance to
> share your
earn cash
<http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV>
<http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV>>
> > _______________________________________________
> > Geoserver-users mailing list
> > Geoserver-users@lists.sourceforge.net
<mailto:Geoserver-users@lists.sourceforge.net>
<mailto:Geoserver-users@lists.sourceforge.net>>
> > https://lists.sourceforge.net/lists/listinfo/geoserver-users
<https://lists.sourceforge.net/lists/listinfo/geoserver-users>
> > !DSPAM:1004,45dd7b92265781775926497!
> Justin Deoliveira
> The Open Planning Project
> http://topp.openplans.org
> !DSPAM:1004,45dda452285031665516417!
