[Geoserver-users] Label Displacement Question
Java 8
GeoServer 2.8.3
Working through my issue to label my latitude lines at the “ends” of the line, I have this section of my label rule to tell me where it “is supposed to be”
sld:TextSymbolizer
sld:Label
<ogc:Function name=“strSubstring”>
ogc:PropertyNamebottom</ogc:PropertyName>
<ogc:Function name=“parseInt”>
ogc:Literal0</ogc:Literal>
</ogc:Function>
<ogc:Function name=“strIndexOf”>
ogc:Literal.</ogc:Literal>
</ogc:Function>
</ogc:Function>
Expected Label Location<![CDATA[
<ogc:Function name=“Concatenate”>
ogc:LiteralPOINT(</ogc:Literal>
<ogc:Function name=“strSubString”>
<ogc:Function name=“env”>
ogc:Literalwms_bbox</ogc:Literal>
</ogc:Function>
ogc:Add
</ogc:Function>
ogc:Literal:</ogc:Literal>
</ogc:Function>
ogc:Literal2</ogc:Literal>
</ogc:Add>
</ogc:Function>
ogc:Literal,</ogc:Literal>
</ogc:Function>
</ogc:Function>
ogc:Literal</ogc:Literal>
<ogc:Function name=“getY”><ogc:Function name=“endPoint”>ogc:PropertyNamegeom</ogc:PropertyName></ogc:Function></ogc:Function>
ogc:Literal)</ogc:Literal>
</ogc:Function>
Blah blah other labels, font etc
</sld:Label>
</sld:TextSymbolizer>
</sld:Rule>
sld:Rule
sld:Namelabel rule</sld:Name>
sld:LineSymbolizer
sld:Stroke
<sld:CssParameter name=“stroke”>#66A61E</sld:CssParameter>
</sld:Stroke>
</sld:LineSymbolizer>
sld:TextSymbolizer
sld:Geometry
<ogc:Function name=“geomFromWKT”>
</ogc:Function>
ogc:Add
</ogc:Function>
</ogc:Function>
</ogc:Add>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</sld:Geometry>
sld:Label
</ogc:Function>
</ogc:Function>
</ogc:Function>°0’0"
</sld:Label>
sld:Font
<sld:CssParameter name=“font-family”>Arial</sld:CssParameter>
<sld:CssParameter name=“font-size”>10.0</sld:CssParameter>
<sld:CssParameter name=“font-style”>normal</sld:CssParameter>
<sld:CssParameter name=“font-weight”>normal</sld:CssParameter>
</sld:Font>
0.0
0.0
40
0
0
sld:Fill
<sld:CssParameter name=“fill”>#0000FF</sld:CssParameter>
</sld:Fill>
</sld:Rule>
However, I get the label ~96 pixels from the LEFT of the output image instead of the expected 40 pixels from the RIGHT of the output (see image with → Expect Point)
I added another rule (first one above) to print at standard location where it is expected to be before moving with the displacement. (Image not to full size)
Is there something I am missing in my rules, or mistaking what the displacement is supposed to do? My understanding is it should be XX pixels from the geometry point.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@anonymised.com
Chris,
I don’t know if this will help or hinder you, but this is where I got to, for some reason it only works for the Western (left hand) edge in general, and will display the other edges only at the extremes
Ian
<?xml version="1.0" encoding="ISO-8859-1"?>
grid A teal line style teal line #00cc33 the_geom wms_bbox
</ogc:Function>
</ogc:Function>
<ogc:Function name=“intersection”>
ogc:PropertyNamethe_geom</ogc:PropertyName>
</ogc:Function>
</ogc:Function>
</ogc:Function>
0.0 0.0 -120 40 0 the_geom wms_bbox
</ogc:Function>
</ogc:Function>
<ogc:Function name=“startPoint”>
</ogc:Function>
</ogc:Function>
</ogc:Function>
0.0 0.0 0 -20 0
On 7 November 2016 at 23:37, Chris Snider <chris.snider@…3225…> wrote:
Java 8
GeoServer 2.8.3
sld:TextSymbolizer
sld:Label
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
ogc:Add
</ogc:Function>
</ogc:Function>
</ogc:Add>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</sld:Label>
</sld:Rule>
sld:Rule
sld:LineSymbolizer
sld:Stroke
</sld:Stroke>
sld:TextSymbolizer
sld:Geometry
</ogc:Function>
ogc:Add
</ogc:Function>
</ogc:Function>
</ogc:Add>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</sld:Geometry>
sld:Label
</ogc:Function>
</ogc:Function>
</sld:Label>
sld:Font
</sld:Font>
0.0
0.0
40
0
0
sld:Fill
</sld:Fill>
</sld:Rule>
Chris Snider
Description: Description: Description: cid:image001.png@...5633...
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today. http://sdm.link/xeonphi
Geoserver-users mailing list
Geoserver-users@…382…sourceforge.net
Ian Turton
Ian,
Great pointer to the right direction. I took what you said about the extreme edge and realized I needed to invert my logic. Instead of trying to place the label on the right edge and backing it up by the expected pixel size, I start at the left edge and add the displacement as the env:wms_width, subtracting my expected label pixel size. No ratio algorithm, but it is easy enough to generate my label with a new font size, display it, then capture a portion to determine the width in pixels from Paint.NET or some such, and use that in the calculation of the env:wms_width – PIXEL_SIZE.
For those that are interested, here is the complete SLD for my latitude set
<sld:StyledLayerDescriptor xmlns=“http://www.opengis.net/sld” xmlns:sld=“http://www.opengis.net/sld” xmlns:gml=“http://www.opengis.net/gml” xmlns:ogc=“http://www.opengis.net/ogc” version=“1.0.0”>
sld:UserLayer
sld:LayerFeatureConstraints
sld:FeatureTypeConstraint/
</sld:LayerFeatureConstraints>
sld:UserStyle
sld:Namegridshape lon 10.0 deg</sld:Name>
sld:FeatureTypeStyle
sld:Namegroup 0</sld:Name>
sld:FeatureTypeNameFeature</sld:FeatureTypeName>
sld:SemanticTypeIdentifiergeneric:geometry</sld:SemanticTypeIdentifier>
sld:SemanticTypeIdentifiersimple</sld:SemanticTypeIdentifier>
sld:Rule
sld:LineSymbolizer
sld:Stroke
<sld:CssParameter name=“stroke-width”>.1</sld:CssParameter>
</sld:Stroke>
sld:TextSymbolizer
sld:Geometry
</ogc:Function>
ogc:Add
</ogc:Function>
ogc:Literal[</ogc:Literal>
</ogc:Function>
ogc:Literal1</ogc:Literal>
</ogc:Add>
ogc:Sub
</ogc:Function>
</ogc:Function>
</ogc:Sub>
</ogc:Function>
ogc:Literal
</ogc:Literal>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</sld:Geometry>
sld:Label
</ogc:Function>
</ogc:Function>
</sld:Label>
sld:Font
<sld:CssParameter name=“font-size”>8.0</sld:CssParameter>
</sld:Font>
0.0
0.0
ogc:Sub
ogc:Literalwms_width</ogc:Literal>
</ogc:Function>
ogc:Literal33</ogc:Literal>
</ogc:Sub>
0
0
sld:Halo
sld:Radius3</sld:Radius>
sld:Fill
<sld:CssParameter name=“fill”>#FFFFFF</sld:CssParameter>
</sld:Fill>
</sld:Halo>
sld:Fill
<sld:CssParameter name=“fill”>#000000</sld:CssParameter>
</sld:Fill>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:UserLayer>
</sld:StyledLayerDescriptor>
Chris Snider
Chris,
Ian
<StyledLayerDescriptor version=“1.0.0”
xsi:schemaLocation=“http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd
xmlns=“http://www.opengis.net/sld” xmlns:ogc=“http://www.opengis.net/ogc
xmlns:xlink=“http://www.w3.org/1999/xlink” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”>
grid
#00cc33
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
0.0
0.0
-120
40
0
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
0.0
0.0
0
-20
0
Java 8
GeoServer 2.8.3
sld:TextSymbolizer
sld:Label
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
ogc:Add
</ogc:Function>
</ogc:Function>
</ogc:Add>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</sld:Label>
</sld:Rule>
sld:Rule
sld:LineSymbolizer
sld:Stroke
</sld:Stroke>
sld:TextSymbolizer
sld:Geometry
</ogc:Function>
ogc:Add
</ogc:Function>
</ogc:Function>
</ogc:Add>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</sld:Geometry>
sld:Label
</ogc:Function>
</ogc:Function>
</sld:Label>
sld:Font
</sld:Font>
0.0
0.0
40
0
0
sld:Fill
</sld:Fill>
</sld:Rule>
Chris Snider
Ian Turton
Sent again with some prior code trimming
