[Geoserver-users] Label fit problem when followLine=on
Hi!
Is there any way to render a label with followLine=on if the label doesn’t fit on the line (the line is too short for the whole label) ?
A fallback to followLine=off would be a nice feature in this case.
Cheers!
  • Anssi
On Tue, Jul 5, 2016 at 7:45 AM, Kanninen Anssi EXT <Anssi.Kanninen@anonymised.com..
wrote:
Hi!
As far as I know, there isn't
Agreed... I guess it would have to be an extra option, I personally would
not consider a tiny line with a very long label a good output,
but would not mind a bit of overshoot (we'd need some sort of "goodness of
fit" for lines, to allow people choosing how much of
overshoot is acceptable).
In case you are interested in working towards it, here is a guide:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
