[Geoserver-users] Label fit to polygon
Hi there,
I want a help as I am new to geoserver.
I have to show labels of polygon only if label fit inside the polygon geometry.
How can we do this?
I tried goodnessofFit vendorOption but this was not worked out.
Thanks for help in advance.
On Thu, Sep 10, 2015 at 1:04 PM, Aastha Aggarwal <aasthaggrwl@anonymised.com>
wrote:
Hi there,
geometry.
How can we do this?
goodnessOfFit=1 should work, can you show us the SLD, and show how it has
not
worked out?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi below is the SLD and attached screenshot of label showing out of polygon.
Exchange_Area Default Polygon A sample style that draws a polygon SHAPE LABEL 0.5 0.5 3 #FFFFFF #000000 1
Thanks
Aastha
On Thu, Sep 10, 2015 at 1:04 PM, Aastha Aggarwal <aasthaggrwl@anonymised.com> wrote:
Hi there,
How can we do this?
goodnessOfFit=1 should work, can you show us the SLD, and show how it has not
worked out?
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Sep 10, 2015 at 2:17 PM, Aastha Aggarwal <aasthaggrwl@anonymised.com>
wrote:
     <Geometry>
          <ogc:Function name="centroid">
            <ogc:PropertyName>SHAPE</ogc:PropertyName>
          </ogc:Function>
        </Geometry>
I believe this is the reason why it's not working, with the transformation
applied
the code thinks it's labeling a point, not a polygon, so goodness of fit is
not applied.
I'm not aware of a way to make it label the centroid, but consider the
polygon for
the fit checks.
Ing. Andrea Aime
@geowolf
Technical Lead
Hey thanks,
I removed centroid that goodnessofFit worked but the label is showing repetitive all over the polygon.
On Thu, Sep 10, 2015 at 2:17 PM, Aastha Aggarwal <aasthaggrwl@anonymised.com…> wrote:
SHAPE
I believe this is the reason why it’s not working, with the transformation applied
the code thinks it’s labeling a point, not a polygon, so goodness of fit is not applied.
I’m not aware of a way to make it label the centroid, but consider the polygon for
the fit checks.
Ing. Andrea Aime
@geowolf
Technical Lead
