Do you use OpenLayers or tiles with some other application? Try using single tile mode.
-Jukka Rahkonen-
Aastha Aggarwal wrote:
Hey thanks,
I removed centroid that goodnessofFit worked but the label is showing repetitive all over the polygon.
Sent: 10-09-2015 17:51
To: Aastha Aggarwal
Subject: Re: [Geoserver-users] Label fit to polygon
On Thu, Sep 10, 2015 at 2:17 PM, Aastha Aggarwal <aasthaggrwl@…84…> wrote:
SHAPEI believe this is the reason why it’s not working, with the transformation applied
the code thinks it’s labeling a point, not a polygon, so goodness of fit is not applied.
I’m not aware of a way to make it label the centroid, but consider the polygon for
the fit checks.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
