Am I overlooking something or is there no way to displace my road
labels in a CSS generated style?
If it is missing where should I look for the code so I can see if I can add it?
Ian
Ian Turton
Ian
Ian Turton
I pulled the code for the actual translation process into the geoscript Scala variant a month or so ago, so it’s hosted on github with the rest of that project. However, I don’t think you’ll need to dig into it just yet since displacement is there but undocumented.
For a line placement with offset:
label: [foo];
label-offset: 10px;
For a point placement with anchor point, offset and rotation:
label: [foo];
label-offset: 10px 10px;
label-anchor: 25% 25%;
label-rotation: 45deg;
If you’re still itching to provide a patch, this is missing from the documentation. All of these properties should be included in the main properties list at http://docs.geoserver.org/stable/en/user/community/css/properties.html; a patch for the Sphinx sources would be greatly appreciated.
David Winslow
OpenGeo - http://opengeo.org/
On Thu, Sep 16, 2010 at 11:56 AM, Ian Turton <ijturton@anonymised.com> wrote:
labels in a CSS generated style?If it is missing where should I look for the code so I can see if I can add it?
Ian
Ian Turton
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
Geoserver-users mailing list
On Thu, Sep 16, 2010 at 12:12 PM, David Winslow <dwinslow@anonymised.com> wrote:
Scala variant a month or so ago, so it's hosted on github with the rest of
that project. However, I don't think you'll need to dig into it just yet
Thanks - I'll look at the docs when I get a free moment.
Ian
