I'm having difficulties to solve a problem using Geoserver. I looked into
Label tutorial but there's nothing there that can help me to fix it.
The problem is.
I have a map and some dots (square) layers that make reference to addresses.
Some are from the same neighborhood, so they are the same color. To
differentiate him, I use a Label with a number, perhaps, sometimes the label
don't seem's visible on the map, and I need that all of them be visible.
Anyone can help-me on this? There's a image attached showing the problem and
a sld file. My Geoserver version is 1.7.1
It looks like you're running afoul of GeoServer's built-in label conflict resolution. There is currently a ticket open to allow this to be (selectively) turned off:
The problem is.
