[Geoserver-users] Label repeats
Hi there
I am facing a problem with the labels of polygons.
The problem is that I have them (the labels) repeated many times over the polygons.
Any idea or help ?
Thanks in advance
Fernando.
Luis F Silva ha scritto:
Hi there
Any idea or help ?
Hmmm... the only way I know to get multiple labels in the same polygon
is to use a tiled client, otherwise you should get only one.
Is this your case? If so, there are two solutions:
* use the meta-tiler, that will only mitigate the issue, not fully solve
   it. See:
   http://docs.codehaus.org/display/GEOSDOC/WMS+vendor+parameters
* if you're using OpenLayer as the client, make it so the label layer is
   a separate overlay. The geometric layers will stay tiled, while you
   can setup the label layer as untiled. This means the labels will have
   to be recomputed each time the client moves, but at least they will be
   guaranteed having no repetitions (for an example of how to set up
   an untiled layer, see our map preview page source from your browser).
Hope this helps
That’s my case.
I am going to take your recommendations and see what is the best for us.
By the way: Do you have any known tips to improve the performance when working with GeoServer and OpenLayers ?
Any recommendation in terms of GeoServer configuration , for example ?
Thanks in advance
Fernando.
Andrea Aime aaime@anonymised.com
08/10/2007 10:39
To
Luis F Silva lfsilva@anonymised.com
cc
geoserver-users@lists.sourceforge.net
Subject
Re: [Geoserver-users] Label repeats
> Hi there
> the polygons.
> Any idea or help ?
it. See:
Hope this helps
That's my case.
Yes, I have a few:
1) have a look at these presentation:
    http://www.foss4g2007.org/presentations/view.php?abstract_id=120
    http://www.foss4g2007.org/presentations/view.php?abstract_id=111
2) follow directions here: http://docs.codehaus.org/display/GEOSDOC/4+GeoServer+in+Production+Environment
3) Use Geoserver 1.6.0beta3 (official release) or nightlies from here:
    http://geo.openplans.org/nightly/trunk/
4) Keep your styles simple, avoid translucency if possible (that is,
    keep opaque == 1), make sure to display as few information as
    possible using zoom levels and other filter options in SDL Rule
    elements (in particular, try to keep labelling at a minumum, it's
    the slowest part of our rendering chain).
Hope this helps
Thank you very much for the tips you sent to me.
Once we are going to have 100% of our maps being generated in dynamic basis , using remote SLD , performance is something that I worry about; mainly because of our inexperience with GeoServer , SLDs , and so on.
I am going to follow them and compare the the time processing between the current stage and the new one.
Thanks again for your attention
Best Regards
Fernando.
09/10/2007 03:36
To
cc
Subject
> Andrea
> That's my case.
Yes, I have a few:
Hope this helps
May I ask why you need to use remote SLD extensively?
I read in your presentation that png256 is the best to be used.
Do you have an example of how to use it ? Where can I find an already done pallete ?
Thanks in advance
Fernando.
09/10/2007 03:36
To
cc
Subject
> Andrea
> That's my case.
Yes, I have a few:
Hope this helps
Everything is in the docs:
http://docs.codehaus.org/display/GEOSDOC/Paletted+images+tutorial
http://docs.codehaus.org/display/GEOSDOC/FOSS4G+2007+Workshop
  (see optimizing wms output)
I drove some tests and notice that when using image/png8 or image/jpeg with Openlayers just produce “pink” tiles.
Is it a limitation ?
TIA
Fernando
09/10/2007 13:04
To
cc
Subject
> Andrea
> done pallete ?
I drove some tests and notice that when using image/png8 or image/jpeg with Openlayers just produce "pink" tiles.
Nope, sounds like a bug, but you'll have to provide me more information
to track it down. Or else, GeoServer is not able to provide OL the
tiles fast enough.
Try adding "OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;" in your javascript
so that tile loading is retried. If that does not help, look in the
geoserver logs for more info.
The "OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;" was already there.
The log seems to be ok.
I copied the last lines below:
127.0.0.1 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/openlayers/img/blank.gif HTTP/1.1” 200 42
192.168.0.220 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-96.878794%2C-33.751314%2C-73.991482%2C-10.864002 HTTP/1.1” 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-96.878794%2C-10.864002%2C-73.991482%2C12.023311 HTTP/1.1” 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-119.766106%2C-33.751314%2C-73.991482%2C12.023311 HTTP/1.1” 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-119.766106%2C-79.525938%2C-73.991482%2C-33.751314 HTTP/1.1” 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-73.991482%2C-10.864002%2C-51.10417%2C12.023311 HTTP/1.1” 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-73.991482%2C-33.751314%2C-51.10417%2C-10.864002 HTTP/1.1” 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-51.10417%2C-33.751314%2C-28.216857%2C-10.864002 HTTP/1.1” 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-51.10417%2C-10.864002%2C-28.216857%2C12.023311 HTTP/1.1” 200 352
192.168.0.220 - - [09/10/2007:17:27:32 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-73.991482%2C-79.525938%2C-28.216857%2C-33.751314 HTTP/1.1” 200 909
192.168.0.220 - - [09/10/2007:17:27:31 +0000] “GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-73.991482%2C-33.751314%2C-28.216857%2C12.023311 HTTP/1.1” 200 352
Let me know if you need/want any more info.
Fernando.
09/10/2007 14:39
To
cc
Subject
tiles fast enough.
127.0.0.1 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/openlayers/img/blank.gif HTTP/1.1" 200 42
192.168.0.220 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-96.878794%2C-33.751314%2C-73.991482%2C-10.864002 HTTP/1.1" 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-96.878794%2C-10.864002%2C-73.991482%2C12.023311 HTTP/1.1" 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-119.766106%2C-33.751314%2C-73.991482%2C12.023311 HTTP/1.1" 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-119.766106%2C-79.525938%2C-73.991482%2C-33.751314 HTTP/1.1" 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-73.991482%2C-10.864002%2C-51.10417%2C12.023311 HTTP/1.1" 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-73.991482%2C-33.751314%2C-51.10417%2C-10.864002 HTTP/1.1" 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-51.10417%2C-33.751314%2C-28.216857%2C-10.864002 HTTP/1.1" 200 352
192.168.0.220 - - [09/10/2007:17:27:24 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-51.10417%2C-10.864002%2C-28.216857%2C12.023311 HTTP/1.1" 200 352
192.168.0.220 - - [09/10/2007:17:27:32 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-73.991482%2C-79.525938%2C-28.216857%2C-33.751314 HTTP/1.1" 200 909
192.168.0.220 - - [09/10/2007:17:27:31 +0000] "GET /geoserver/wms?WIDTH=256&HEIGHT=256&FORMAT=image%2Fjpeg&TILED=true&TILESORIGIN=-73.991482%2C-33.751314&SLD=http%3A%2F%2F192.168.0.220%3A8084%2FPms%2FSupSvr%3Freq%3DgetSldAsRemote%26id%3DPms119195084343919367195425019&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-73.991482%2C-33.751314%2C-28.216857%2C12.023311 HTTP/1.1" 200 352
That's just the Jetty log, not GeoServer's one. In the configuration/server panel enable log to file, then
generate one pink tile (stop as soon as you see one)
and the look in the geoserver data directory for the
geoserver log.
The options to activate the log are there , but not available to changes.
Is there a properties file , or something like that , where I could activate it ?
Fernando.
09/10/2007 15:01
To
cc
Subject
> Andrea
> HTTP/1.1" 200 352
> HTTP/1.1" 200 352
> HTTP/1.1" 200 352
> HTTP/1.1" 200 352
> HTTP/1.1" 200 352
> HTTP/1.1" 200 352
> HTTP/1.1" 200 352
> HTTP/1.1" 200 352
> HTTP/1.1" 200 909
> HTTP/1.1" 200 352
geoserver log.
Hmm... this sounds like a bug, but I don't know how to replicate it.
Saul, do you know of any reason why the UI won't allow the user
to alter the logging configuration?
The UI won't let geoserver change the logging configs iff commons-logging
isn't set up to backend onto log4j. I.e. if the commons-logging.properties
file doesn't contain
org.apache.commons.logging.Log=org.apache.commons.logging.impl.Log4JLogger
Otherwise allowing logging profile changes should definitely be enabled.
Luis, if you're using geoserver 1.5.x, then this is all moot, since the
mildly-revamped logging UI isn't present except in the 1.6.x series.
SEPERATELY: I can confirm that tiled wms images get 'pinkified'. It
appears to be related to the metatiler, but doesn't produce any strange
logging. Here is an example of the phenomenon:
WITHOUT TILING (no TILE_ORIGIN, etc params in url):
http://giswebservices.massgis.state.ma.us/geoserver/wms?LAYERS=massgis%3AGISDATA.ASSESSPARNC_POLY_STATUS&STYLES=&HEIGHT=256&WIDTH=256&SRS=EPSG%3A26986&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=223803.183119%2C892017.092233%2C265707.952406%2C933921.86152
WITH TILING (includes TILE_ORIGIN, etc params in url):
http://giswebservices.massgis.state.ma.us/geoserver/wms?LAYERS=massgis%3AGISDATA.ASSESSPARNC_POLY_STATUS&STYLES=&HEIGHT=256&WIDTH=256&SRS=EPSG%3A26986&FORMAT=image%2Fpng&TILED=true&TILESORIGIN=14279.336685607384%2C766302.7843728303&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=223803.183119%2C892017.092233%2C265707.952406%2C933921.86152
Note the green tint in the lower half of the second image...this is a
strange artifact that only appears when using the tiling params.
--saul
activate it ?
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Label-repeats-tf4588219.html#a13217563
