[Geoserver-users] Labeling in SLD - label the right field
I have problem with labeling - I can't figure out how to pick the right
field to label!
My data looks like this (from a wfs request):
<http://osgeo-org.1560.n6.nabble.com/file/n5023729/quest.jpg&gt;
What I want to label is stored in the field named 'oso:katunumero' (1). As
you can see, it is now stored under the field 'oso:osoite' (2).
Seems like an easy issue, but I can't figure out how to pick that
'oso:katunumero' from there.
Labeling it with <Label><ogc:PropertyName>katunumero</ ></ > gives an error:
.... The style specifies an attribute of katunumero and the layer is:
mtk:oso_Osoitepiste
        <TextSymbolizer>
          <Label>
            <ogc:PropertyName>??</ogc:PropertyName>
regards,
Jakob
View this message in context: http://osgeo-org.1560.n6.nabble.com/Labeling-in-SLD-label-the-right-field-tp5023729.html
I believe you should include the prefix along with the name:
ogc:PropertyNameoso:katunumero</ogc:PropertyName>
On Tue, Dec 18, 2012 at 6:08 AM, obtin <jventin@anonymised.com> wrote:
I have problem with labeling - I can’t figure out how to pick the right
field to label!
<http://osgeo-org.1560.n6.nabble.com/file/n5023729/quest.jpg>
What I want to label is stored in the field named ‘oso:katunumero’ (1). As
you can see, it is now stored under the field ‘oso:osoite’ (2).
Seems like an easy issue, but I can’t figure out how to pick that
‘oso:katunumero’ from there.
Labeling it with ogc:PropertyNamekatunumero</ ></ > gives an error:
… The style specifies an attribute of katunumero and the layer is:
mtk:oso_Osoitepiste
regards,
Jakob
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-users mailing list
thanks for that tip, unfortunately it did not seem to work..
for clarity:
when using
<Label>
<ogc:PropertyName>rakenustunnus</ogc:PropertyName>
</Label>
it works fine and labels whatever is stored under oso:rakennustunnus.
Any further ideas?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Labeling-in-SLD-label-the-right-field-tp5023729p5023844.html
How is the hierarchical GML being generated? Are you using AppSchema, or is the underlying Datastore creating this?
AFAIK you can’t refer to nested attributes in SLD elements (but perhaps someone else can confirm if that is correct). If so, you need to find a way to “flatten” the layer schema to make the desired attribute accessible.
On Tue, Dec 18, 2012 at 3:08 AM, obtin <jventin@anonymised.com> wrote:
field to label!
mtk:oso_Osoitepiste
regards,
Jakob
Martin Davis
OpenGeo - http://opengeo.org
I believe Niels did work in order to make it possible to access a nested
property via xpath some time ago, with features generated by app-schema
Cc’ed him
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
That is true. With the app-schema module included (in the future, complex module) you are able to evaluate x-paths against complex features (returns properties) or against feature types (returns descriptors). This has also been applied in SLD files for using WMS with app-schema. There are examples that demonstrate that this works.
Kind Regards
Niels
On 12/19/2012 04:32 PM, Andrea Aime wrote:
On Wed, Dec 19, 2012 at 4:16 PM, Martin Davis <mdavis@anonymised.com <mailto:mdavis@anonymised.com>> wrote:
    AFAIK you can't refer to nested attributes in SLD <PropertyName>
    correct). If so, you need to find a way to "flatten" the layer
Cc'ed him
Ing. Andrea Aime
@geowolf
Technical Lead
Are the examples documented anywhere for the OP to look at?
On Thu, Dec 20, 2012 at 4:47 AM, Niels Charlier <niels@anonymised.com…4960…> wrote:
Kind Regards
Niels
Cc’ed him
Ing. Andrea Aime
@geowolf
Technical Lead
Martin Davis
Read here for more information
http://docs.geoserver.org/latest/en/user/data/app-schema/wms-support.html
With examples I mainly meant unit tests. Look in the app-schema-tests module in geoserver for the following classes:
WmsGetMapTest
WmsGetFeatureInfoTest
WmsGetLegendGraphicTest
They use SLD files also included in the module.
Hope this helps.
Niels
On Thu, Dec 20, 2012 at 4:47 AM, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
    works.
    Kind Regards
    Niels
        <PropertyName> elements (but perhaps someone else can confirm
        "flatten" the layer schema to make the desired attribute
        accessible.
    nested
    app-schema
    Cc'ed him
    Ing. Andrea Aime
    @geowolf
    Technical Lead
    phone: +39 0584 962313 <tel:%2B39%200584%20962313>
    fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
    mob: +39 339 8844549 <tel:%2B39%20%C2%A0339%208844549>
Martin Davis
OpenGeo - http://opengeo.org/&gt;
back at work after some vacation.
In our case, the WFS-sevice is produced outside Geoserver, on Degree WFS /
Oracle 11g Locator platform. Is it possible to apply Geoserver nested
property via xpath in a situation where the complex featured WFS-service is
gotten outside of Geoserver?
Jakob
View this message in context: http://osgeo-org.1560.n6.nabble.com/Labeling-in-SLD-label-the-right-field-tp5023729p5025603.html
