[Geoserver-users] labeling polygons
Hi All,
can anybody help me?
I'm using Geoserver in combination with Google Earth.
The problem I met is labeling polygons.
I think/suspect the label position is calculated by the boundary box coordinates of the polygon.
So e.g. with curved polygons or polygons with a holes in it, labels are placed outside the polygon.
Are there options in SLD to ensure that each label is placed inside the polygon?
Jan
Deze e-mail en de inhoud daarvan is vertrouwelijk.
Het is mogelijk dat tijdens het opstellen of het transport van dit bericht fouten zijn ontstaan zodat het bericht onjuist of onvolledig is overgekomen of verkeerd is geadresseerd. Hiervoor kan ProRail geen aansprakelijkheid erkennen. Uitsluitend een document dat door een bevoegd persoon namens ProRail is ondertekend is bindend. De inhoud van dit bericht mag niet openbaar worden gemaakt, vermenigvuldigd of worden verspreid aan derden. Wij verzoeken u om bij twijfel over de juistheid, de volledigheid of de adressering de e-mail direct te retourneren en daarna te vernietigen.
This e-mail and its contents are confidential.
It is possible that during the making or transmission of this message errors have arisen, so that this message is improperly or incompletely dispatched or has wrongfully been addressed. In this case, ProRail cannot be held liable. Only a document which has been signed by an authorized person on behalf of ProRail is binding. The contents of this e-mail may not be disclosed, copied or dispatched to anyone. In case of doubt about the correctness, the completeness or the address, you are requested to reply the e-mail immediately and then destroy the e-mail.
Hi Jan,
You will need to develop SLD's and freemarker templates to control the
KML output.
I refer you to http://geoserver.org/display/GEOSDOC/KML+Placemark+Templates.
Groetjes,
Jason
On Mon, Sep 1, 2008 at 1:07 PM, <jan.rombout@anonymised.com> wrote:
Hi All,
Jan
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Sorry, GeoServer simply uses the centroid of the polygon; there's no way to configure this behavior short of fixing it in the code. I have created a ticket in our bug tracker for this issue; you can watch http://jira.codehaus.org/browse/GEOS-2189 for updates.
-David Winslow
jan.rombout@anonymised.com wrote:
Hi All,
The problem I met is labeling polygons. I think/suspect the label position is calculated by the boundary box coordinates of the polygon. So e.g. with curved polygons or polygons with a holes in it, labels are placed outside the polygon.
Jan
