[Geoserver-users] labeling problem with font size
hi,
for some strange reason geoserver doesn't change the stylining included in
(see a piece of SLD below); nor the font-family nor font-size... are applied
on GetMap when they are modified. But, for example, <Halo> is sensible to
these changes.
I wonder, why?? the SLD below is extracted from
http://geoserver.org/display/GEOSDOC/ComplexLabelingExample and Geoserver
doesn't complain about anything.
Some idea?
ah, congratulations for GeoExt Styler! I wonder if styling labels will be
also possible on the near future?
thanks
         <Rule>
         <MaxScaleDenominator>52000000</MaxScaleDenominator>
          <TextSymbolizer>
          <Label>
        <ogc:PropertyName>code</ogc:PropertyName>
      </Label>
      <CssParameter name="font-family">Verdana</CssParameter>
      <CssParameter name="font-style">Normal</CssParameter>
      <CssParameter name="font-size">20</CssParameter>
              <!-- this centers the label on the polygon's centroid-->
        <LabelPlacement>
          <PointPlacement>
            <AnchorPoint>
          <AnchorPointX>0.5</AnchorPointX>
          <AnchorPointY>0.5</AnchorPointY>
        </AnchorPoint>
          </PointPlacement>
        </LabelPlacement>
        <Halo>
          <Radius>
       <ogc:Literal>8</ogc:Literal>
          </Radius>
          <Fill>
      <CssParameter name="fill">#FFFFFF</CssParameter>
      <CssParameter name="fill-opacity">0.7</CssParameter>
          </Fill>
        </Halo>
            </TextSymbolizer>
        </Rule>
View this message in context: http://www.nabble.com/labeling-problem-with-font-size-tp21850830p21850830.html
It looks like you are missing a "<Font>" element. I believe it should be:
<Font>
</Font>
Also, are you using the styler extension from 1.7.2? Support for styling labels is available in it.
-Justin
pere roca wrote:
hi, for some strange reason geoserver doesn't change the stylining included in (see a piece of SLD below); nor the font-family nor font-size... are applied
these changes.
Some idea? ah, congratulations for GeoExt Styler! I wonder if styling labels will be
thanks
         <Rule>
          <TextSymbolizer>
          <Label>
      </Label>
        <LabelPlacement>
          <PointPlacement> <AnchorPoint>
        </AnchorPoint>
          </PointPlacement> </LabelPlacement>
        <Halo> <Radius>
          </Radius>
          <Fill>
      <CssParameter name="fill-opacity">0.7</CssParameter> </Fill>
        </Halo>
            </TextSymbolizer>
        </Rule>
Justin Deoliveira
OpenGeo - http://opengeo.org
sorry, it was my fault when typing the message; the Font element is on the SLD and I can appreciate some changes but… just an example: what do I have to do if I want the province names much bigger (see first GetMap below)? I have applied a font-size= 2000 but I just see a very little difference with a GetMap applying the old style (without font-size; see second GetMap) ; it seems as if there is a limit… depending on what?
thanks in advance,
Pere
APPLYING STYLE (eu_negro3 with font-size 2000)
http://edit.csic.es/geoserver/wms?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=topp:province_iberia,topp:test_csvimportgispoints2&SRS=EPSG:4326&BBOX=-0.6934896568304696,40.02588284415445,4.120762384103197,42.765026246754644&WIDTH=1132&HEIGHT=556&FORMAT=image/png&styles=eu_negro3,&TRANSPARENT=TRUE&UNIQUEID=
NO STYLE
http://edit.csic.es/geoserver/wms?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=topp:province_iberia,topp:test_csvimportgispoints2&SRS=EPSG:4326&BBOX=-0.6934896568304696,40.02588284415445,4.120762384103197,42.765026246754644&WIDTH=1132&HEIGHT=556&FORMAT=image/png&styles=&TRANSPARENT=TRUE&UNIQUEID=
that part of SLD is correct but seems not enough??..
Verdana
Normal
2000
2009/2/5 Justin Deoliveira <jdeolive@anonymised.com.1671…>
It looks like you are missing a “” element. I believe it should be:
Verdana Normal 20
-Justin
pere roca wrote:
hi, for some strange reason geoserver doesn’t change the stylining included in (see a piece of SLD below); nor the font-family nor font-size… are applied
on GetMap when they are modified. But, for example, is sensible to
these changes.
doesn’t complain about anything.
thanks
52000000 code Verdana Normal 20 0.5 0.5 8 #FFFFFF 0.7
Justin Deoliveira
Pere Roca Ristol
Biòleg i especialista GIS
Museo Nacional de Ciencias Naturales (CSIC)
Visita l’EDIT mapViewer!
http://edit.csic.es/edit_geo/prototype/edit.html
Hi Pere,
Are you sure the font is found? That doesn’t seem to be Verdana. I had these problems in Linux and fixed them by copying ttf-fonts from Windows and then applying the whole path to the font-family tag, like:
/path-to-directory-where-I-copied-the-ttf-file/Verdana.ttf
  • mika -
pere roca ristol kirjoitti:
pere roca ristol ha scritto:
sorry, it was my fault when typing the message; the Font element is on the SLD and I can appreciate some changes but... just an example: what do I have to do if I want the province names much bigger (see first GetMap below)? I have applied a font-size= 2000 but I just see a very little difference with a GetMap applying the old style (without font-size; see second GetMap) ; it seems as if there is a limit... depending on what?
There is no limit, I've just tried setting the population style
label size to 30, Verdana, at here is the result.
Have you done the usual apply-save cycle after submitting changes
to the style?
Andrea Aime
that is! the Fonts where not there and Geoserver was missing the Font tag; now it works after setting the full path to fonts.
I’m wondering why the fonts where not there (are not installed along with Geoserver?) and how to make a cleaner solution (avoiding to write full path to fonts).
thank you very much!
Pere
2009/2/5 Mika Lehtonen <mika@anonymised.com>
Hi Pere,
  • mika -
thanks in advance,
Pere
NO STYLE
Verdana
Normal
2000
2009/2/5 Justin Deoliveira <jdeolive@anonymised.com1…>
Verdana Normal 20
-Justin
these changes.
thanks
Justin Deoliveira
Pere Roca Ristol
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-[http://p.sf.net/sfu/adobe-com](http://p.sf.net/sfu/adobe-com)
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Pere Roca Ristol
Those fonts cannot be distributed with GeoServer (or Linux distributions) for legal reasons, but most distributions have instructions on how to install them. However, the JVM doesn't always look in the right places, so see the last paragraph of
http://geoserver.org/display/GEOSDOC/1.1.4+CentOS+(Red+Hat)+5.1+Install
That's the lazy way of making sure Java will find them.
-Arne
   I'm wondering why the fonts where not there (are not installed along with Geoserver?) and how to make a cleaner solution (avoiding to write full path to fonts).
  Pere
2009/2/5 Mika Lehtonen <mika@anonymised.com <mailto:mika@anonymised.com>>
    Hi Pere,
    Are you sure the font is found? That doesn't seem to be Verdana. I
    tag, like:
    <CssParameter
    name="font-family">/path-to-directory-where-I-copied-the-ttf-file/Verdana.ttf</CssParameter>
    - mika -
    thanks in advance,
    Pere
    <http://edit.csic.es/geoserver/wms?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=topp:province_iberia,topp:test_csvimportgispoints2&SRS=EPSG:4326&BBOX=-0.6934896568304696,40.02588284415445,4.120762384103197,42.765026246754644&WIDTH=1132&HEIGHT=556&FORMAT=image/png&styles=eu_negro3,&TRANSPARENT=TRUE&UNIQUEID=&gt;
    NO STYLE
    <http://edit.csic.es/geoserver/wms?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=topp:province_iberia,topp:test_csvimportgispoints2&SRS=EPSG:4326&BBOX=-0.6934896568304696,40.02588284415445,4.120762384103197,42.765026246754644&WIDTH=1132&HEIGHT=556&FORMAT=image/png&styles=&TRANSPARENT=TRUE&UNIQUEID=&gt;
    that part of SLD is correct but seems not enough??...
    <Font> <CssParameter name="font-family">Verdana</CssParameter> <CssParameter name="font-style">Normal</CssParameter> <CssParameter name="font-size">2000</CssParameter> </Font>
    <mailto:jdeolive@anonymised.com>>
        it should be:
        <Font>
        </Font>
        -Justin
            these changes.
             and Geoserver
            thanks
                    <Rule>
                     <TextSymbolizer>
                     <Label>
                 </Label>
                               <CssParameter
            centroid-->
                   <LabelPlacement>
                   </AnchorPoint>
                     </PointPlacement> </LabelPlacement> <Halo> <Radius>
                     </Radius>
                     <Fill>
                             </Fill>
                   </Halo>
                       </TextSymbolizer>
                   </Rule>
        -- Justin Deoliveira
    -- Pere Roca Ristol
    Visita l'EDIT mapViewer!
    Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
    Geoserver-users@lists.sourceforge.net <mailto:Geoserver-users@anonymised.comsourceforge.net>
Pere Roca Ristol
Arne Kepp
