[Geoserver-users] Labels drawn over graphic elements
Dear GeoServer users,
I have a layer which shows data from a meteorology station network in using very specific graphics symbol.
The symbol consists of a colored square to the left and a colored rectangle to the right of feature's anchor point, with a possibility of label drawn over the rectangle.
I'm using my custom PNG icons as <ExternalGraphic> and choose the right colors according to feature data as follows:
<Rule>
     <Name>stations</Name>
     <PointSymbolizer>
         <Graphic>
             <ExternalGraphic>
                 <OnlineResource xlink:type="simple" xlink:href="file://station_${TENDENCY}_${SPA}_${PREC}_${TEMP_DRY}_${TEMP_WATER}.png"/>
                 <Format>image/png</Format>
             </ExternalGraphic>
         </Graphic>
     </PointSymbolizer>
     <TextSymbolizer>
         <Label>
             <ogc:PropertyName>TEXT</ogc:PropertyName>
         </Label>
         <Font>
             <CssParameter name="font-family">Arial</CssParameter>
             <CssParameter name="font-size">14</CssParameter>
             <CssParameter name="font-style">normal</CssParameter>
             <CssParameter name="font-weight">bold</CssParameter>
         </Font>
         <LabelPlacement>
             <PointPlacement>
                 <AnchorPoint>
                     <AnchorPointX>0</AnchorPointX>
                     <AnchorPointY>0</AnchorPointY>
                 </AnchorPoint>
                 <Displacement>
                     <DisplacementX>-2</DisplacementX>
                     <DisplacementY>4</DisplacementY>
                 </Displacement>
             </PointPlacement>
         </LabelPlacement>
         <Fill>#FFFFFF</Fill>
     </TextSymbolizer>
</Rule>
The problem is that the icons might overlap and when they do the text is drawn always on top, regardless of relative z-index of the icon it belongs to. Here's an example: http://imgur.com/YxwieHW
It seems to me all graphics are rendered first and all labels are rendered after.
What can I do about it?
I tried using shapes from SLD styles but I need to use more than one shape for every feature. GeoServer renders multiple shapes centered around anchor point and there is no possibility to use Displacement for graphic (AFAIK it's possible only with text labels). That's why I use ExternalGraphic, I need to show all shapes side by side.
Many thanks
Peter Kovac
IMS Programmer
MicroStep-MIS
peter.kovac@anonymised.com
On Mon, Oct 12, 2015 at 6:45 PM, Peter Kovac <peter.kovac@anonymised.com>
rendered after.
Displacement for graphics is supported in recent versions of GeoServer
(since 2.7
I believe).
About the ability to avoid drawing all labels at the end, it has been
discussed,
in normal situation it just breaks maps big time, as the WMS user can
compose
them in any order they want and labels need to stay on top to be legible,
but we understand there are cases in which this might not be desirable (for
example when labels are not really labels, but more parts of symbols).
For this we'd need to add and code support for a new "drawImmediately"
vendor
option. So far no one has provided either their own coding time to make it
a reality,
or funding to allow core developers to add this features during working
hours.
Maybe you could be the one? :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Dear Andrea,
thank you for clearing it up for me. As you’d might guess, my company is interested in the “drawImmediately” vendor option. So we either code it ourselves or we will fund core developers, depending on time/money costs. Do you remember if this feature was discussed among developers before? Who and where should I ask about GeoServer developers’ time and money estimates?
Peter Kovac
On 12. 10. 2015 19:50, Andrea Aime wrote:
On Mon, Oct 12, 2015 at 6:45 PM, Peter Kovac <peter.kovac@anonymised.com> wrote:
rendered after.
graphic (AFAIK it’s possible only with text labels). That’s why I use
Displacement for graphics is supported in recent versions of GeoServer (since 2.7
I believe).
About the ability to avoid drawing all labels at the end, it has been discussed,
in normal situation it just breaks maps big time, as the WMS user can compose
For this we’d need to add and code support for a new “drawImmediately” vendor
option. So far no one has provided either their own coding time to make it a reality,
or funding to allow core developers to add this features during working hours.
Ing. Andrea Aime
@geowolf
Technical Lead
Peter Kovac
IMS Programmer
MicroStep-MIS
[peter.kovac@anonymised.com](mailto:peter.kovac@anonymised.com)
On Wed, Oct 14, 2015 at 7:47 AM, Peter Kovac <peter.kovac@anonymised.com>
wrote:
Dear Andrea,
thank you for clearing it up for me. As you'd might guess, my company is
interested in the "drawImmediately" vendor option. So we either code it
Hum... nope, I don't remember a developer discussion ever happened on this
topic.
Who and where should I ask about GeoServer developers' time and money
estimates?
The list of commercial support providers is here:
http://geoserver.org/support/
Ing. Andrea Aime
@geowolf
Technical Lead
