Serving my own street layers (shapefiles) on top of google maps (satellite
view) and google earth just fine. (WFS)
1.- Im Using the <VendorOption name="group">yes</VendorOption> in both the
street and city layers; With the streets layer the label placement works ok
(one label per street) but city layer ignores the grouping instruction and
displays names more than once (6 or 7).
2.- The other thing is that I would like to place the city label in an
specific location of the map, let´s say, in the upper left corner, next to
the zoom control, and have no idea on how to do that.
Suggestions? ... Thanks !
I have a sugestion for (1):
Try to use <VendorOption name="group">true</VendorOption> instead of <VendorOption name="group">yes</VendorOption>.
Are city layers polygons or lines? I think the vendor group option only works for lines, I was noticing that behavior myself last night. The docs say that it should do grouping:
polygons are (a) clipped to the view rectangle (b) the centroid of the largest polygon is used.
Next to the zoom control? Like you always want it next to the zoom control? Even when someone moves around or zooms in? That's hard to do, since the zoom control isn't really an element of the map GeoServer produces, so it doesn't know where it is. If you really wanted it right by the zoom control then I'd write it in to the client. Have the client make a WFS GetFeature request to figure out what city was being viewed (simple way is just do a GetFeature for the center of the map, you could get in to more complicated algorithms though, for cases when multiple cities are on the map, ect.) And then display the results next to the zoom.
If you're using google maps then you'll have to write some javascript code to make the request and to put the results on top of the map (or it might be easier to do it just outside? I'm not sure). There's info on how to make WFS requests in javascript at: http://docs.codehaus.org/display/MAP/Step+3+Set+Up+Queries
Layer Provinces : Polygon
Layer County: Polygon
Layer Towns: Point
to
zoom.
Im using Google Maps, and when I said next to the zoom control is to
give you an idea of what could be anywhere, top left, bottom right,
doesn't matter, just want the names displayed like in an specific area,
city name and below province name, when you move the map, it goes back
to the same spot, let's say, xxxx pixels, yyyyyy pixels from the upper left
corner
of the map.
Eduardo:
