[Geoserver-users] labels separated from lines
I know that it's possible for a label to follow the ligne with the
VendorOption name="followLine">true< parameter.
But in that case, the label is on the line. Is it possible to separate it
from the line like it's possible to do with a point with the deplacement
parameter?
Thanks a lot,
Pascal.
View this message in context: http://osgeo-org.1560.x6.nabble.com/labels-separated-from-lines-tp5088746.html
Check “PerpendicularOffset”
http://docs.geoserver.org/latest/en/user/styling/sld-reference/labeling.html#perpendicularoffset
Edward
Date: Tue, 12 Nov 2013 04:11:43 -0800
Subject: [Geoserver-users] labels separated from lines
I know that it’s possible for a label to follow the ligne with the
VendorOption name=“followLine”>true< parameter.
from the line like it’s possible to do with a point with the deplacement
parameter?
Thanks a lot,
Pascal.
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
On Tue, Nov 12, 2013 at 1:23 PM, Edward Mac Gillavry <
emacgillavry@anonymised.com> wrote:
Check "PerpendicularOffset"
Mind, it's only supported when not using the followLine vendor option, as
we don't have yet
ability to compute proper offset curves.
I should start working on that topic soon tough.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
