On Wed, Oct 8, 2014 at 2:16 AM, Tom S <tom-sourceforge@anonymised.com>
wrote:
I am in the process of deploying a newly installed (geo)server, and have
hit an odd problem. The new system is a complete refresh (OS,
postgreSQL, Java, Tomcat, ...), but I don't think most of these changes
are relevant. The old system is running geoServer 2.4.2, and the new
one uses 2.5.2. Both have identical layer and style definitions
configured, and otherwise have similar setups. When I pull a specific
PNG based tile from the old system the size is about half that from the
new system with the exact same query/result. Does anyone have any
suggestions on places to check to find why there is such a notable
difference in the results?
Your description is quite generic, so I'm going to have to make a few
guesses.
When you say larger, do you mean the size of the output in bytes?
I guess you were running on Windows, where GeoServer was using the JDK
built-in PNG encoder that did not respect our compression hints, and was
spending
a very large amount of time trying to get the smallest possible image,
whilst
in 2.5.x we have a pure java version, which is noticeably faster, and that
does respect the PNG compression parameters configured in the WMS panel.
If you want smaller PNGs you can try increasing the compression rate in the
WMS
panel. Also, have you tried the png8 compression (image/png8), it should
also
improve quite a bit the size of the result, with a un-noticeable loss in
quality
(well, unless you're trying to serve aerial imagery, in this case PNG is
simply
the wrong format, use JPEG instead).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
