Hi guys,
I have just committed some changes to GeoServer 1.4.x WCS branch which:
1- fix the building against new GeoTools 2.3.x changes to filters
2 - should fix the InlineFeatures problems
3 - shoulc fix the OracleDataStore problems
For the latter … has someone some SQL pieces to insert into an Oracle database in order to do some testing on my side?
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Hi Alessio,
You guys are just too darn efficient over on that branch :). As for
testing oracle, a while back I ported the DataStoreAPITest from postgis
to oracle on the complex-features. Nothing about it is particular to
that branch so it would be easy enough to port to geotools trunk.
-Justin
Alessio Fabiani wrote:
Hi guys,
For the latter ... has someone some SQL pieces to insert into an Oracle
!DSPAM:1004,450e9d49212781804284693!
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Justin Deoliveira
jdeolive@anonymised.com
The Open Planning Project
http://topp.openplans.org
