Hello,
I have several shapefile datastores and I would like to show in a client application the set of attributes for a given layer. Is it possible to obtain the set of data columns via WFS?
Thanks in advance,
Santi
Hello,
Thanks in advance,
Santi
On Tue, May 14, 2013 at 12:22 PM, Santiago Timón <stimonmail@anonymised.com>wrote:
Hello,
Use the DescribeFeatureType WFS request, it gives you back the xml schema
of the GML, which in turns contains all elements and their types
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thank you Andrea, I will try it.
Santi
2013/5/14 Andrea Aime <andrea.aime@anonymised.com>
On Tue, May 14, 2013 at 12:22 PM, Santiago Timón <stimonmail@anonymised.com> wrote:
Hello,
Use the DescribeFeatureType WFS request, it gives you back the xml schema of the GML, which in turns contains all elements and their types
Ing. Andrea Aime
@geowolf
Technical Lead
