[Geoserver-users] Layer edit : Cannot find JNDI data source: java:comp/env/jdbc/postgres
Hi All,
I am trying to help a friend to fix his Geoserver 2.6.0 installation on Ubuntu Server, after some changes (a but unclear to me what happened ). Symptom is in the web interface when clicking on ‘edit layer’ the top liste this error:
failed to load attribute list, internal error is: Cannot find JNDI data source: java:comp/env/jdbc/postgres
Any idea what this means (or indicates what might have gone wrong) or ho to fix?
Karsten
Karsten Vennemann
Principal
Terra GIS LTD
www.terragis.net
Hi. There is a problem with connection to the database, where the layer data is. My advice is to delete layer. Then check the store, if it is still valid and connection ok. After that you can try to republish the layer. I have not used Postgis layers via JNDI. My way is to create use Postgis store directly. There are 2 alternatives, to create a Postgis store, with JNDI or without it.
Oiva Hakala, Natural Resources Institute Finland
Lähettäjä: karsten karsten@anonymised.com
Lähetetty: 20. elokuuta 2015 22:57
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] Layer edit : Cannot find JNDI data source: java:comp/env/jdbc/postgres
Hi All,
Karsten
Karsten Vennemann
Principal
Terra GIS LTD
www.terragis.net
On Thu, Aug 20, 2015 at 9:57 PM, karsten <karsten@anonymised.com> wrote:
Hi All,
Symptom is in the web interface when clicking on 'edit layer' the top liste
this error:
to fix?
It means what it says, that the JNDI source cannot be found. Did you
configure it correctly in your web container?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea and Luke,
thank you soo much for your answers.
While your responses did not help me to directly sole the problem they got me thinking more about the message JNDI source not found … then I poked around the GeoServer doc http://docs.geoserver.org/stable/en/user/tutorials/tomcat-jndi/tomcat-jndi.html how to configure that connection driver and finally stumbled about the configuration file with is located in the tomcat home directory TOMCAT_HOME/conf/context.xml …which is /etc/tomcat7/context.xml in our servers.
I then compared the files /etc/tomcat7/context.xml in our live and the dev server (that was messed up) and found that the file on dev did not have any resource (data base connection tag) configured.
So what must have happened it that tomcat7 had been upgraded by someone and at that time the config.xml file was overwritten with the default file.
So to fix I replaced that file on dev with the live file version (attached) and restarted tomcat and voila all layers all working again.
Lesson to be learned is that when updating tomcat7 one need to copy also that config.xml file and update after installation to make the Geoserver layers based on (postgres) JNDI connections work.
Karsten
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Friday, August 21, 2015 4:10
To: karsten@anonymised.com
Cc: GeoServer Mailing List List
Subject: Re: [Geoserver-users] Layer edit : Cannot find JNDI data source: java:comp/env/jdbc/postgres
Hi All,
It means what it says, that the JNDI source cannot be found. Did you configure it correctly in your web container?
Ing. Andrea Aime
@geowolf
Technical Lead
