Thank you very much for your response.
I think I understood the limitations of my idea.
Let me ask you another question: I have an SLD (described right below) where the only layer (in fact the layer group) “country” is mentioned with some rules and filters.
That SLD is generated on the fly , according to the user’s needs and couple selected options , and may become much greater than the one showed below , that’s why it is served from a remote servlet throught an url.
The whole thing is between the … tags and so I would like to know if there is a way to have , in an SLD , many layers mentioned but with just one set of rules, filters, symbolizers and so on.
It may solve my problem , once I could code the 27 states as layers and just one collection of rules and filters , to avoid having SLDs with large sizes.
This is one example of my SLD:
country
UserSelection
STATECODE
33
#5F9EA0
NAME
Arial
Normal
8
#000000
0.5
0
#000000
1
Thanks again
Fernando.
Andrea Aime aaime@anonymised.com
04/10/2007 13:41
To
Luis F Silva lfsilva@anonymised.com
cc
geoserver-users@lists.sourceforge.net
Subject
Re: [Geoserver-users] Layer Group and remote SLD (url)
Luis F Silva ha scritto:
> Hi all
> I created a layer group (country) that joins 27 features (states) and
> named it "mycountry".
> Those features have some atributes (like "state_code" and "name") that
> are common to all of them.
> Then I tested it throught GetMap request and it worked fine , using the
> features default styles (that are the same for all of them too).
> The problem is that when I try to display the same group but using a
> remote SLD throught an url I get no image or better , in fact I get some
> frames (once I am using OpenLayers) with the "red cross" that says it
> could not load the image(s).
> So I have couple questions: Is it possible to call a remote SLD even
> when using a Layer group ? If so: Is that SLD description applicable to
> all the features that are part of such group ?
A layer group is something that is expanded server side into a list
of layers and styles, so the actual WMS renderer does not see it at all.
The issue is, when you specify a remote SLD to use, that's basically
replaces layers and styles parameters. It's not like you can specify
just the styles in that document, you have to re-specify everything,
and there layer grouping does not work at all.
If you need to perform filtering I suggest you use our custom WMS
extensions for filtering, adding either an OGC filter or a CQL
filter to the request. If you specify just one filter, it should
work just fine (it will be applied to all layers).
For more information, see:
http://docs.codehaus.org/display/GEOSDOC/WMS+vendor+parameters
Hope this helps
