How do I add the TIME dimension to a layer group so that it shows in the getCapabilities document? Each layer added to the layer group has the time dimension enabled and all contain the same time.
Dominique
Dominique
On Thu, Oct 22, 2015 at 12:32 AM, Bessette-Halsema, Dominique E <
As far as I know, only by changing the code, I'm not aware of any dimension
configuration bit for layer groups.
It's also a bit tricky, to make it work properly the same dimensions should
have the same value list for
all layers, otherwise for certain values some would show, others would not
(we are still missing the
"match nearest" support for user provided dimension values).
I guess the second concern could also be addressed by documentation (thus
assuming the admin will check
the values line up), the first could be checked
automatically on configuration, what we'd still need is the code to handle
that... and decide what to
do for groups in tree mode (as opposed to single layer mode).
We have a bit of guidance for those looking for a improvement/new feature
here:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
