[Geoserver-users] Layer Groups within Layer Groups
Has anyone had any problems with Layer Groups within Layer Groups? I have a number of these set up and the “child” Layer Groups (between 2 and 3) have disappeared from the “parent”. In some cases they’ve all disappeared and in others they’ve left one behind.
When I tried to add them back in via the Web Admin then open them up again they haven’t disappeared again! I needed to fix this ASAP so I just deleted the parent groups and re-added them with the same names and they appear to be working as normal (for now).
All of the Groups where in this format:
PARENT Layer Group > 2-3 CHILD Layer Groups > 3-7 SHP files from same directory
Any thoughts?
Many thanks,
Rob
<br>DISCLAIMER: The information contained in this communication/message from Robert.Langford@anonymised.com..5490... sent on Thu Jul 25 10:23:38 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) geoserver-users@anonymised.comists.sourceforge.net<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.<br>Please immediately contact the sender, Robert.Langford@anonymised.com if you have received this message in error.<br><br>For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.<br>
All,
Sorry forgot to include details:
GeoServer: 2.3.3
Apache Tomcat: 7.0.41
JVM Version: 1.6.0_45-b06
Windows Server 2008 R2
Rob
Sent: 25 July 2013 10:24
To: ‘geoserver-users@lists.sourceforge.net’
Subject: Layer Groups within Layer Groups
Any thoughts?
Many thanks,
Rob
<br>DISCLAIMER: The information contained in this communication/message from Robert.Langford@anonymised.com..5490... sent on Thu Jul 25 10:28:24 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) geoserver-users@anonymised.comists.sourceforge.net<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.<br>Please immediately contact the sender, Robert.Langford@anonymised.com if you have received this message in error.<br><br>For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.<br>
On Thu, Jul 25, 2013 at 11:23 AM, Langford, Robert <
Robert.Langford@anonymised.com> wrote:
Hi all,****
and in others they’ve left one behind.****
appear to be working as normal (for now).****
All of the Groups where in this format:****
directory****
Any thoughts?
No clue. If you manage to find a reproducable, step by step process to make
this happen,
please open a bug report at jira.codehaus.org (if you don't have an
account, get one at xircles.codehaus.org)
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Rob,
I’ve not had that particular issue, but I have had some other issues with Layer Groups within LayerGroups; they do tend to be a bit flaky, though I can’t put my finger on exactly what the issue is. (Also using 2.3.3). It’s definitely worth keeping a close eye on them for unexpected behaviour whenever some aspect of them or their constituent layers is changed.
Jonathan
On 25 July 2013 10:23, Langford, Robert <Robert.Langford@anonymised.com> wrote:
Any thoughts?
Many thanks,
Rob
<br>DISCLAIMER: The information contained in this communication/message from [Robert.Langford@anonymised.com..5490...](mailto:Robert.Langford@anonymised.com) sent on Thu Jul 25 10:23:38 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) [geoserver-users@lists.sourceforge.net](mailto:geoserver-users@lists.sourceforge.net)<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act. <br>Please immediately contact the sender, [Robert.Langford@anonymised.com](mailto:Robert.Langford@anonymised.com.5490...) if you have received this message in error. <br><br>For the full disclaimer please access [http://www.salford.gov.uk/e-mail](http://www.salford.gov.uk/e-mail). Thank you.<br>
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
All,
I’ve caught this happening on my test environment (contains a copy of the data_dir from live), a parent Layer Group should have 3 child Layer Groups but only 1 is being shown (in Web Admin & via WMS).
In the relevant folder: […]\workspaces\WORKSPACE_NAME\layergroups
I have XML files for a parent Layer Group and it’s 3 child Layer Groups.
Opening them up in a text editor appears to look normal, with the corresponding values for the children in the parent and I’ve also checked the children values to their constituent layers – all matching.
I also checked the bounds of the parent, they appeared to be a little too small (although I doubt that is the root cause); as a test I manually edited the parent Layer Group XML to extend the bounds and restarted GeoServer.
Through the web interface the bounds were updated but the same 2 child Layer Groups were still missing.
Attempting to save the Parent via the Web Admin results in an error “java.lang.IllegalArgumentException: Layer group has different number of styles than layers
Adding the missing child Layer Groups back in the correct order allows a save but then the parent Layer Group has the missing layer Groups removed from the XML (although all 3 tags still remain). Going back into the parent Layer Group in Web Admin results in the same error as above.
Is there anything else I can check or try before I have to resolve this (probably by removing the parent Layer Group and re-adding it)? Can/should I open a bug report as I cannot recreate it (I’ve tried)?
Jonathan/Andrea – thanks for your comments.
Rob
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com.]
Sent: 25 July 2013 12:02
To: Langford, Robert
Subject: Re: [Geoserver-users] Layer Groups within Layer Groups
Hi Rob,
Jonathan
Any thoughts?
Many thanks,
Rob
<br>DISCLAIMER: The information contained in this communication/message from [Robert.Langford@anonymised.com](mailto:Robert.Langford@anonymised.com) sent on Thu Jul 25 10:23:38 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) [geoserver-users@lists.sourceforge.net](mailto:geoserver-users@lists.sourceforge.net)<br>
<br><br>
<br>Please immediately contact the sender, [Robert.Langford@anonymised.com](mailto:Robert.Langford@anonymised.com) if you have received this message in error. <br>
<br><br>
<br>DISCLAIMER: The information contained in this communication/message from Robert.Langford@anonymised.com..5490... sent on Thu Jul 25 15:03:17 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) andrea.aime@anonymised.com07...;geoserver-users@lists.sourceforge.net;jonathanmoules@anonymised.com<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.<br>Please immediately contact the sender, Robert.Langford@anonymised.com if you have received this message in error.<br><br>For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.<br>
Hi Robert,
from your description seems the same problem fixed with GEOS-5847.
Unfortunately the fix has been applied to 2.4 only, since it was a bit tricky.
We can evaluate if the backport of the fix is worth to have or you can test the 2.4 beta and see if you can wait for the final release to come out.
Mauro Bartolomeoli
All,
Rob
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Hi Rob,
Jonathan
Any thoughts?
Many thanks,
Rob
<br> <br>
<br> <br>
<br>DISCLAIMER: The information contained in this communication/message from [Robert.Langford@anonymised.com..](mailto:Robert.Langford@anonymised.com) sent on Thu Jul 25 15:03:17 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) [andrea.aime@anonymised.com](mailto:andrea.aime@anonymised.com);[geoserver-users@lists.sourceforge.net](mailto:geoserver-users@lists.sourceforge.net);[jonathanmoules@anonymised.com](mailto:jonathanmoules@anonymised.com...)<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act. <br>Please immediately contact the sender, [Robert.Langford@anonymised.com](mailto:Robert.Langford@anonymised.com.5490...) if you have received this message in error. <br><br>For the full disclaimer please access [http://www.salford.gov.uk/e-mail](http://www.salford.gov.uk/e-mail). Thank you.<br>
Mauro,
Thanks for this – this is exactly the problem and it explains why only some Layer Groups were affected.
So for the benefit of others I’ll point out that it appears that the Layer Groups are loaded on start-up in alphabetical order (therefore my problem didn’t arise until I restarted GS); therefore if a child Layer Group is alphabetically later than it’s parent it won’t be possible to reference it in the parent.
I’ve tested this by renaming and stop/starting.
So it’s looking like my solution is either; always name parent Layer Groups alphabetically later than any child of it (probably a suffix would be easiest), wait for GS 2.4, or use GS 2.4 beta.
I will try to have a look at the beta on my test setup.
Thanks for everyone’s contributions.
Rob
From: maurobartolomeoli@anonymised.com [mailto:maurobartolomeoli@anonymised.com] On Behalf Of Mauro Bartolomeoli
Sent: 25 July 2013 16:16
Cc: GeoServer Mailing List List
Hi Robert,
Mauro Bartolomeoli
All,
Rob
Cc: geoserver-users@anonymised.comt
Hi Rob,
Jonathan
Any thoughts?
Many thanks,
Rob
<br>DISCLAIMER: The information contained in this communication/message from [Robert.Langford@anonymised.com](mailto:Robert.Langford@anonymised.com) sent on Thu Jul 25 10:23:38 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) [geoserver-users@lists.sourceforge.net](mailto:geoserver-users@anonymised.com.net)<br>
<br> <br>
<br>Please immediately contact the sender, [Robert.Langford@anonymised.com...](mailto:Robert.Langford@anonymised.com) if you have received this message in error. <br>
<br> <br>
<br>DISCLAIMER: The information contained in this communication/message from [Robert.Langford@anonymised.com](mailto:Robert.Langford@anonymised.com) sent on Thu Jul 25 15:03:17 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) [andrea.aime@anonymised.com](mailto:andrea.aime@anonymised.com);[geoserver-users@lists.sourceforge.net](mailto:geoserver-users@lists.sourceforge.net);[jonathanmoules@anonymised.com](mailto:jonathanmoules@anonymised.com)<br>
<br><br>
<br><br>
Geoserver-users@anonymised.come.net
<br>DISCLAIMER: The information contained in this communication/message from Robert.Langford@anonymised.com..5490... sent on Thu Jul 25 17:00:28 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) mauro.bartolomeoli@anonymised.com;geoserver-users@lists.sourceforge.net<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.<br>Please immediately contact the sender, Robert.Langford@anonymised.com if you have received this message in error.<br><br>For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.<br>
Hi Rob,
Thanks for the summation. Turns out upon investigation that I was experiencing this; my LayerGroup of LayerGroups was broken on the live server (which is reset daily) but working on the test server. Fortunately that’s a test layer so I doubt anyone noticed yet. I’ll probably rename my parent layergroup to start with Z_ for the interim.
Jonathan
On 25 July 2013 17:00, Langford, Robert <Robert.Langford@anonymised.com> wrote:
Mauro,
Rob
Hi Robert,
Mauro Bartolomeoli
All,
Rob
Hi Rob,
Jonathan
On 25 July 2013 10:23, Langford, Robert <Robert.Langford@anonymised.com…5490…> wrote:
Any thoughts?
Many thanks,
Rob
<br> <br>
<br> <br>
<br>DISCLAIMER: The information contained in this communication/message from [Robert.Langford@anonymised.com0...](mailto:Robert.Langford@anonymised.com) sent on Thu Jul 25 15:03:17 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) [andrea.aime@anonymised.com](mailto:andrea.aime@anonymised.com);[geoserver-users@lists.sourceforge.net](mailto:geoserver-users@lists.sourceforge.net);[jonathanmoules@anonymised.com](mailto:jonathanmoules@anonymised.com2...)<br>
<br> <br>
<br> <br>
<br>DISCLAIMER: The information contained in this communication/message from [Robert.Langford@anonymised.com..5490...](mailto:Robert.Langford@anonymised.com) sent on Thu Jul 25 17:00:28 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) [mauro.bartolomeoli@anonymised.com.1107...](mailto:mauro.bartolomeoli@anonymised.com);[geoserver-users@lists.sourceforge.net](mailto:geoserver-users@lists.sourceforge.net)<br><br><br><br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act. <br>Please immediately contact the sender, [Robert.Langford@anonymised.com](mailto:Robert.Langford@anonymised.com.5490...) if you have received this message in error. <br><br>For the full disclaimer please access [http://www.salford.gov.uk/e-mail](http://www.salford.gov.uk/e-mail). Thank you.<br><br>
