Save the file and open it with a text editor. It may be an error message that can help you further.
-Jukka Rahkonen-
Pedro wrote:
I add a postgis view to Geoserver.
When I go to Layer Preview (Openlayers), instead of having a map it ask me if I want to safe a file...
In QGIS, when I add a WFS connection to that same Geoserver Layer I get a correct answer (it show me the layer)
In the postgis table/view my geom column is type (Geometry,4326) The Layer Preview maybe related to the geometry type?
Check the geoserver log to see if there are any errors.
If not, make sure that the bounding box used by the preview (check the actual URL) contains actual data. If it does, verify that you can use one of the default styles (point, poly or line).
/julian
-----Oprindelig meddelelse-----
Fra: Pedro [mailto:pedro.ferro@anonymised.com]
Sendt: 17. november 2015 16:19
Til: geoserver-users@lists.sourceforge.net
Emne: Re: [Geoserver-users] Layer Preview
Well it seems that my problem in Layer Preview is now different
Layer Preview any of the preloaded data in OpenLayers and I just get a blank map.
