Hello,
I am trying to change the style associated with a Shapefile.
I created a new style using graphical interface and I entered it in the list of styles.
The steps to add a new style in Geoserver, using graphics interface are:
- Select “Style”;
- “Add new style”;
- Insert name and its text;
- Press “Submit”.
Now the new style is in the style list.
Then, if I join the style to my layer directly through interface of Geoserver 2.02 I am able to visualize it.
In particular, the steps are:
- Select “Layers”;
- Choose a layer and click on its name;
- Select “Publishing” and change “Default Style” to the new style.
If instead, I use the example in the documentation layer becomes “not enabled” and then I can not see it.
Precisely, the example is this: http://docs.geoserver.org/stable/en/user/extensions/rest/rest-config-examples-curl.html
(section Changing a feature type style)
and the command used is:
“curl -u admin:geoserver -XPUT -H ‘Content-type: text/xml’ -d
‘roads_style’
http://localhost:9090/geoserver/rest/layers/acme:roads”
where: roads_style is created style; acme is the workspace and roads is the layer name.
I think that it’s an issue related to the update of the layer but currently I don’t know how I can resolve it.
I also have another question: in Geoserver 2.02 to change the style to layer I must necessarily create layer first and then change its default style?
Precisely, I have to create the layer with this command:
curl -u admin:geoserver -XPOST -H ‘Content-type: text/xml’
-d ‘buildings’
http://localhost:8080/geoserver/rest/workspaces/acme/datastores/nyc/featuretypes
and the I change the style (with curl) as above.
Furthermore, I have the same problem with Raster; I can publish them but I can not change them style.
Do you have any suggestions?
Thank you.
Babi
2010/8/18 Jody Garnett <jody.garnett@anonymised.com>
You may wish to report a bug; it would help if you list the steps to show the problem with the default geoserver dataset (allowing a developer to confirm your actions). It also helps to keep to one question per email; there are a couple of good guides with respect to asking questions online.
Jody
On 06/08/2010, at 7:14 PM, Barbara Cintoli wrote:
Hello,
If I join the style to my layer directly through interface of Geoserver 2.02 I am able to visualize it.
The command used is:
‘roads_style’
Thank you.
Babi
Devo utilizzare Rest per far comunicare la web application con
Geoserver 2.02!
Ho lo stesso problema con i Raster; riesco a fare l’upload ma non
riesco a settargli lo style.
Avete qualche suggerimento?
Grazie
Barbara Cintoli
This SF.net email is sponsored by
Make an app they can’t live without
Enter the BlackBerry Developer Challenge
http://p.sf.net/sfu/RIM-dev2dev _______________________________________________
Geoserver-users mailing list
Barbara Cintoli
