Is it possible to output the visible layers in GeoServer so each layer is separated in the output PDF file?
Regards
Dean Howell
Regards
Dean Howell
On Tue, Jan 6, 2015 at 6:42 AM, Dean Howell <deanhowell2009@anonymised.com>
Not at the moment. But it would be really nice to have someone implement
this capability
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
